Results 1 to 8 of 8
    Scallywag
    1 1/8 threaded fork with modern Stem, possible?
    Project Bike= 95' Trek 950. First Mistake... I wanted to use some handlebars and a stem I had so I bought a 1" to 1 1/8 Inch Quill Stem Adaptor, come to find out Trek switched from a 1" to a 1 1/8 threaded in 91'... I have a 95'. I want to use the fork on the bike but want the flexibility of using a modern Stem. How can I do this? I can't find a 1 1/8 inch Quill Stem adaptor/extension. Can a shim be used?
    _______________________________________________
    08 Intense 5.5
    Reputation: kubikeman's Avatar
    Jun 2010
    dru
    dru is offline
    Yes, they make adapters. The ID of the steerer tube isn't 1 1/8, it's roughly an inch. So you need a 25.4 to 28.6 adapter. Here's a link from EBAY.
    If you had an inch threaded steerer tube you'd need one with a 22.5 mm diameter.
    1-1/8-INCH THREADLESS TO QUILL STEM ADAPTER | eBay
    Drew
    occasional cyclist
    Reputation: drag_slick's Avatar
    Sep 2004
    Scallywag
    Quote Originally Posted by drag_slick View Post
    I tried the 1" to 1 1/8 " and it doesnt hold, be carefull!
    08 Intense 5.5
    Scallywag
    Thank you very much!
    08 Intense 5.5
    Scallywag
    Quote Originally Posted by dru View Post
    Drew
    You Too, thanks!
    08 Intense 5.5
    Sep 2004
    Quote Originally Posted by JDubKC View Post
    whoops... wrong link, i'm NOT using the 1 to 1 1/8 it's a straight 1 1/8, sorry about that...
    This would be the one.
    Zoom Q-5 25.4mm (1-1/8" fork) to 28.6mm (1-1/8" threadless stem)
  1. Replies: 4
    Last Post: 06-18-2012, 01:06 PM
  2. 1" quill stem fitted to 1 1/8th threaded steerer. Is there a shim?
    By LARRYJO in forum Vintage, Retro, Classic
    Last Post: 05-22-2012, 11:56 AM
  3. long threaded steer tube + threadless stem okay?
    By Entrenador in forum General Discussion
    Last Post: 01-19-2012, 12:19 AM
  4. Fox Fork and Shock / Modern is better, but by how much?
    By rearviewmirror in forum Shocks and Suspension
    Last Post: 09-04-2011, 05:18 AM
  5. Modern downhill fork on at Lts 1
    By trailking in forum GT
    Last Post: 04-15-2011, 09:50 AM
