Results 1 to 3 of 3
    '03 Mongoose Sommet headset question.
    I have a '03 Mongoose Sommet frame that i am looking to replace the integrated headset on. Because of the age of the frame, I think the OEM headset maybe was an early version the technology such that the race and bearings are substantially wider in diameter than current integrated headset. Am I SOL or are there wider diameter headsets out there that I haven't been able to find? I have a call into Mongoose, but haven't heard back yet.
    Thanks for any suggestions.
    Former Bike Wrench
    Probably not SOL
    Are there cups pressed internally into the headtube? If so you have a zerostack or "semi-integrated". There is also the old ICBM integrated standard that used larger bearings than the current integrated standards (41mm and 41.8mm). If it is ICBM it will likely say on the upper race and you'll probably have to contact Cane Creek by phone to dig up some bearings for it. I'm pretty sure ICBM went away by 2003 though (my 2001 Schwinn used it).
    Zero Stack showing internal pressed in cup
    Integrated with headtube machined cup
    Thanks for the tip on the "semi-integrated" headset. I had never heard of them before. When I looked them up on the inernet, that's what the Mongoose has. I was able to reach Mongoose and they had some replacement headsets in stock, so I bought one of theirs.
    Thanks again.
  1. 2008 Mongoose Otero Super Replacement Headset
    By allentram in forum Bike and Frame discussion
    Last Post: 10-18-2010, 03:15 PM
  2. 09 Mongoose Teocali headset noise
    By Infiniteone in forum Mongoose-Schwinn
    Last Post: 03-15-2010, 09:55 PM
  3. Mongoose Pro Grand Marquis headset
    By geekrunner in forum Mongoose-Schwinn
    Last Post: 11-24-2007, 10:31 AM
  4. Mongoose Sommet Geometry
    By mudskipper in forum Mongoose-Schwinn
    Last Post: 11-24-2007, 07:29 AM
  5. Mongoose Pro Sommet rear shock
    By mudskipper in forum GT
    Last Post: 06-09-2006, 08:55 PM
