• 12-02-2012
    Nakkoush
    XT vs XTR in terms of durability
    How does Shimano XTR compare to XT in terms of durability?
    I head that XTR is not only lighter than the XT but it wears out much quicker than the XT !!
    Your comments are appreciated ;)
  • 12-02-2012
    ins@ne
    if u are not any pro racer, stick with XT. and when i say XT i mean full brake set (including resin pads, rotors, specific mineral oil etc...). U can find them all in a Shimano XT manual
  • 12-02-2012
    Nakkoush
    Actually I'm buying a bike from bikesdirect... My concern is mainly for the durability.. xtr shimano bike vs xt bike, in addition I'm not a pro racer...
    plus or minus 2 pounds is not an issue as long as durability is more guaranteed.
  • 12-02-2012
    Timeless
    I have always viewed XT as more durable than XTR.
    My under standing is XTR sacrifices durability to reduce weight but XTR is high end racing.
  • 12-02-2012
    MartinS
    Generally speaking, they should be about the same durability wise, XTR uses more expensive materials and construction to get lighter weight at the same or greater strength. My experience having both (current versions) XT and XTR equipped bikes is that some xtr parts like the cranks are noticeably stiffer, and that the higher grade bushings in the derailleurs and shifters seem to last longer. Brakes wise, there isn't a ton of difference in braking quality or weight between XT and XTR in the new models, long term durability (for me) is still unknown.
  • 12-02-2012
    AndrwSwitch
    Exercise some caution in buying from bikesdirect - give the spec a really close read. They're often very optimistic in the spec level they assign to their bikes.
  • 12-02-2012
    limba
    I've owned plenty of both and you can't go wrong with either. XTR is not weaker. It's just as durable but lighter and more refined. Is it worth the extra money? That's up to you to decide.
  • 12-02-2012
    zebrahum
    There's your best advice. Both are roughly equivalent in durability but XTR has to jump through hoops to get it light and durable which is why it costs so much.
  • 12-02-2012
    Deep Thought
    For what it's worth, XTR is covered under warranty for 3 years, while XT is only covered for 2 years.
  • 12-02-2012
    sauprankul
    I've heard that there's XTR Trail and XTR race. Race wears out very quickly, but is the lightest of all.
    :confused:
  • 12-03-2012
    Nakkoush
    that's what I'm also aware of...
  • 12-03-2012
    JoePAz
    XTR is the lightest stuff they make. However being light does not mean durable. If you are serious racer you need light weight stuff and can always have your team bike mechanic replace parts between the races. XT is my vote for the best balance between performance, weight, durability, and of course cost.
    Unless you really need XTR weight savings stick with XT.
  • 12-03-2012
    zebrahum
    :confused:
    I'd stop saying things "wear out" because it's simply not accurate. Nothing Shimano makes is disposable, well not at the top end of the spectrum. XTR trail stuff is made to be more durable and more functional on so called trail bikes while XTR "race" stuff carries on the tradition that XTR has been known for over the years. It is untrue to say that XTR anything wears out quickly unless you had some data to back it up.
    If anyone is truly worried about longevity then they should just go with XT and appease their skeptical soul.
  • 12-03-2012
    wmac
    In the case of bikes direct, it doesn't matter. The wear items people are generally referring to are cassette, chain and chain rings, which are wear items and are all more expensive than XT - and do wear faster than XT. The Bikesdirect bikes do not use XTR, cassette, chain or chain rings. The only thing you get XTR are the derailleurs and shifters, which are the same durability as XT.
  • 12-03-2012
    wmac
    And in the case of true full XT vs XTR comparison wheels and all, you're looking at $1k to save a pound. And double the cost to replace wear items.
  • 12-03-2012
    limba
    Not related to the OP but thread related. I had an XTR rear derailleur on my cross bike for 9-10 years. One day it just stopped shifting. I'd say I got my money's worth out of it. None of my XT rear derailleurs have lasted more than five years. I would still say that's durable enough.
    You really can't go wrong with either.
  • 12-03-2012
    mitzikatzi
    This question was asked in the Beginner's Corner. Deore is plenty good enough for a "beginner Bike" SLX if you have a bigger wallet.
    A common theme seems to be SLX offers the best compromise of cost/weight/performance.
    Having a Full XT or XTR group set won't make you a better or faster rider (unless maybe you are an elite rider)
  • 12-03-2012
    Guerdonian
    XT is a lot more bang for the buck. You can almost buy two XT components for one XTR component. I used to buy XTR and X0(sram) but now all I buy are XT and X9 as they are cheaper to replace, rebuild, etc.... with very similar performance.
    Keep in mind that its a mountain bike, and unless your a weight weenie racer, rich, or get amazing deals, the higher the range, the less cost to performance benefits you see.
  • 12-03-2012
    Deep Thought
    :confused:
    Just to clarify regarding XTR Trail vs XTR Race:
    XTR Race isn't any less durable than XTR Trail, except maybe for the wheels. The weight difference comes from the cranks (double for Race, triple for Trail), and also a couple small features that are on XTR Trail, but left off of XTR Race to save weight. The brake levers on XTR Race are slightly smaller and they also lack the little lever adjustment knob that is found on XTR Trail levers. At the caliper end, XTR Trail pads have cooling fins, whereas the XTR Race calipers come with pads that don't have the cooling fins. Technically, the caliper is actually the same between XTR Race and XTR Trail. It's the pads that are different.
    If you're counting pedals, the Trail pedals have a platform, whereas the Race pedals don't.
    The derailleurs, shifters, and chains are all the same between the two groups, except I'm not sure if the front derailleurs are double or triple specific.
    Again, I wouldn't worry too much about longevity, considering Shimano offers a longer warranty on XTR than they do the other groups.
    This advice is spot on. I've spent loads of time on SLX, XT, and XTR and there isn't that much difference in performance. XT is by far the best bang for your buck.
  • 12-03-2012
    mimi1885
    ^^^this
    Durability is probably about the same. XTR performs better underload than its downline, you'd get better hill shifting than XT for sure. That said I don't know many XTR users who shift like that:).
    Wearing out parts is such a non issue as I'm still trying to wear out the pully on my XTR 951;)
    XTR line are more for performance, ergonomic, weight, looks and obviously bling, but fast wear and durability is not the issue. If you crash and break a lever or derailleur it would be because of the crash not the component line.
    Sent from my iPhone 4s using Tapatalk
  • 12-03-2012
    cpfitness
    I can't stand when people make statements like this. The talk down about bikes direct for what spec level they call their bike but all one has to do is click on the bike and they give you a COMPLETE list of the parts on the bike. IT's not like they are trying to hide anything.
    As someone else noted, generally with bikes direct the description usually means the shifters and deraileurs that you are getting. you typically get a 3rd party crank and then a lower spec cassette and chain. Also Brakes may leave something to be desired, but lets be honest, at the prices they are selling them for, they are very solid bikes.
  • 12-03-2012
    mimi1885
    Here we go again. Mr. My opinion is the fact. Go troll some other site or stay in bd's forum.
    What you're gonna try to break my hands again?
  • 12-03-2012
    cpfitness
    What the **** is your problem? You are a punk. If you got a problem with my opinion, thats fine, but kindly present some kind of useful information to back yourself up instead of talking **** and stop taking this thread off topic. In this case, my opinon is a FACT. Bikes direct lists every part that goes onto their bikes. Nothing is being hidden. now go back to STFU.
  • 12-03-2012
    SCR818
    I've had a few different bikes built up with some of the parts from the last 3 generations (960, 970, 985) of XTR. Also used quite a bit of the last 3 gens of XT. All parts functioned smoothly and lasted long.
    Either way, you won't be disappointed, it's all good.
    My current bike has a combo of XTR/XT and it's great, too.
  • 12-03-2012
    mimi1885
    Yeah, unlike other brands top shelf XTR usually are not much lighter than XT, slx, etc. If you are looking for significant weight save, you may not find it. A combo XTR/XT perform really well. I have a XTR 970 dual lever that I switch the caliper to XT, couldn't be happier.
  • 12-03-2012
    mimi1885
    Funny, you are saying the same thing Andrew said, yet you can't stand it.:rolleyes:
  • 12-03-2012
    cpfitness
    um no, thats not remotely close to the same thing he said. but I already know your reading comprehension completely sucks. keep on trolling the beginner forum Sandusky.
  • 12-03-2012
    wmac
    um no, thats not remotely close to the same thing he said. But i already know your reading comprehension completely sucks. Keep on trolling the beginner forum sandusky.
    wtf is wrong with you? I read what you wrote and it's disgusting - you should be ashamed of yourself. Listen here, do you have any idea who you are writing to?
    You are so lucky this is the internet and the worst thing we can do is reverse look up your ip address and give it our friends who run the internet!
    They are watching everywhere you go on the internet. I already know where you've been in the past half-hour. You are disgusting. I can only imagine the type of person you are. Who looks at that filth? My friends who run the internet are already tracking down your mom to give her your internet browser logs!
    You and your bike make me sick!
  • 12-03-2012
    cpfitness
    lol, ummm okay. have another one
  • 12-03-2012
    wmac
    Don't play dumb. We're watching you. Expect a call from your mom within the hour.
  • 12-03-2012
    cpfitness
    whos the giver and who's the receiver in your relationship with mimi?
  • 12-03-2012
    wmac
    Hey, watch it you off brand bike riding troll.
  • 12-03-2012
    mimi1885
    This is what this genius think is a solution to pinch flat, go figure.
    going tubeless is a $600 investment, putting proper amount of air in tires is free. this one is a no brainer
    what?? Get a clue.
  • 12-03-2012
    wmac
    Just to prove to you that my friends have taken control of your Internet, we found this picture of you and your friends in your iPhoto library:
  • 12-03-2012
    sauprankul
    :eek: wmac, is that 4 real?
    :p
    Better log off... no place is safe.
  • 12-03-2012
    AndrwSwitch
    This thread has gone a bit sideways.
    Couldn't have said it better myself.
    On a bit of a tangent, I have a road bike I bought back in 2000. It was advertised as having 105 components. When I bought it, it had the shifters, derailleurs, crank, bottom bracket, brakes, hubs, I think even the cassette and chain. I don't think there was anything else offered in the 105 set at the time.
  • 12-03-2012
    cpfitness
    what?? Get a clue.
    stop polluting this guys threads with off topic posts. stop stalking me. Why don't you bring up the full context of that statement jackass. so I can prove myself right again.
  • 12-03-2012
    sauprankul
    Anyhows, I think the verdict is that XT for "bang for your buck" and XTR for more longevity and less weight.
    But for a beginner, either is too much.
  • 12-03-2012
    voodoo5
    To sum up, XTR is the best bang for your buck, XT is good for beginners, and X7 is a perfect balance.
  • 12-03-2012
    Axe
    :confused:
    Race does not wear any more quickly. It just has slightly different features - like servo-wave in the brake.
    In my experience XTR is more durable - bearings in shifters, better alloy on crankarms, better bushings in derailleur. But both are quite robust indeed.
    As far as functionality, I only would pick XTR shifters, and cranks for the sole reason of 172.5mm option and narrower stance. If going for XT, I would rather pick SLX for cassette, cranks, brakes, and probably the new Zee for rear derailleur, as it has a short cage option (did not try it yet, but what could be wrong). SLX front derailleur for the double/short cage option.
  • 12-03-2012
    wmac
    I think I own some of this confusion as a result of my Noob buyers guide. I re-read it and I see it can be interpreted as XTR race is less durable than trail and I was referring to the entire group to include wheels. I also made the statement that XTR wears out more quickly rhan other groups and is expensive to replace when I was referring to the chain rings, chain and cassette. I cannot edit it or make changes. I'm sorry.
    As for the OP, the fact of the matter is the question at hand is irrelevant because he is looking at a Bikesdirect bike and it doesn't have XT or XTR chain, chain rings or cassette or brakes for that matter.
    OP, it doesn't fvcking matter.
  • 12-03-2012
    sauprankul
    Just get the best bike you can afford.
    And here's the best XTR bike I could find.
    Front Derailleur XTR
    Rear Derailleur XTR
    Shifters XTR
    Cassette/Freewheel XT
    Chain KMC
  • 12-03-2012
    Axe
    Yes, first thing on my bikesdirect bike that had to go had been horrible Avid Ultimate brakes. And I also sold carbon FSA crankset and replaced with XTR for less money I sold FSA for. This bike is now with Formula RX brakes, but 2012 XT brakes are the best brakes ever. KMC chain is good.
    Great deal anyway.
  • 12-04-2012
    SimpleJon
    Wow this thread is worse than the 29er forums: Nazi salutes, slurs on maternal relationships... in the normally laid back beginners corner ...my god what is the world coming to.
    My two pennies worth...
    I ride 9 speed XT with 9 speed XTR shifters, I am a reasonably experienced XC rider \ tourer \ bikepacker \ amateur racer - it's more than good enough for me. Unless money is no object I would go with Deore, SLX or XT, you won't notice the difference until you develop your fitness and skills.
    I had an M970 XTR RD once and it lasted three rides before I kopped a trail snake and smashed the carbon cage- if it had been a Al cage XT or SLX cage RD it would still have been toast I think - but it damn near broke my heart to waste $200 or whatever it cost so I stick to XT these days.
    Don't know how your skills are, but as a beginner, if like me, you are very likely to crash and break stuff regardless of 'durability', worth bearing in mind before you drop $2k on a gruppo
  • 12-04-2012
    Tone's
    Damn ive missed all the action, wheres cpfitness gone, come back cp.........
  • 12-04-2012
    Hutch3637
    Well after reading this thread, some good points, some not so good. As far as XT or XTR purchase what you can afford. XTR will hold up fine, you will just save on cash and gain a tiny bit of weight for XT.
    Also cpfitness for your comments and comparing other helpful members to a convicted pedophile.....
    Forgot to sign it, so here.
    -Hutch3637
  • 12-04-2012
    ozzybmx
    Damn it, living on the other side of the world ;)
    I was getting excited reading the post too.
  • 12-04-2012
    Axe
    I think SLX is where the value optimum is at.
  • 12-04-2012
    cpfitness
    -Hutch3637
    Helpful member? Kindly show me how he was of any value to the op in this thread. He doesn't like the fact a "newb" with 100posts has made him look silly by disproving his erroneous statements so he has a vendetta against me. Oh no, what shall i do?
    Sent from my DROID RAZR using Tapatalk 2
  • 12-04-2012
    heyyall
    I've yet to wear something out that isn't supposed to wear out (e.g., chain) by pure use. Cleaning, maintenance and proper use means stuff will out last your interests in a bike.
