Results 1 to 6 of 6
    Xt M775 Compatible?
    Does anyone know if the Shimano XT M775 disc brakes are compatible with the XT M765 dual control shifter/brake lever?
    T.W.O.
    Reputation: mimi1885's Avatar
    Do you mean XT M775 disc calipers are compatible to XTM765 lever/shifter, Yes they do.
    What do you have?
    Thanks, I have a set of XT M765 shifter/levers and I want to buy the newer brake calipers but I don't know if they will work together.
    T.W.O.
    You don't even have to buy XT level it can be Deore or LX it would work. Check your fork what kind of mount you have PM or IS. If possible get the PM caliper for the front, it would make setting up the front brake a breeze.
    Don't have a fork yet. I'm building a new bike and had the extra lever/shifters from my current bike. Will keep your advice in mind. Do you happen to know if the M775 calipers have better adjustment than M765
    T.W.O.
    There's no adjustment on the caliper, on most calipers all the bells and whistles are at the lever.
