    XT 785 Front Derailleur Compatibility
    Just curious as to whether or not this derailleur is 3 ring compatible and how to make sure it will work with the shift system I have on my bike. Cable comes up from the bottom of my bike. Its a Cannondale Trail SL4 and I am looking around to prepare for when things break
    Mar 2011
    There is two different derailleurs for double or triple applications. So if you want to change you need a new derailleur. If you have XT shifters there is a little switch for 2x or 3x underneath. So those will not need to be changed.
    B A N N E D
    The 785 is 2-speed low-clamp.
    For three-speed you want either a 781 (high clamp) or 780 (low clamp).
    Find Front Derailleurs: The Best Mountain Bike Derailleurs/ Shifters From Performance Bike
    I converted from 3x to 2x and really like it. I ended up eventually replacing everything but the crank. But if you want to go 2x I would get started with just a 2x FD and remove the big ring. A 3x shifter (even the SLX that does not have the 2x/3x switch) will work just fine with 2x.
  1. Dura ace 7900 front-rear derailleur and xtr m 980 shifters compatibility
    By Erhar in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-26-2013, 11:56 AM
  2. Stumpjumper FSR Front Derailleur Compatibility
    By nafrod in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-23-2012, 12:11 PM
  3. Sram X0 front derailleur compatibility?
    By Spikes in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-11-2012, 07:06 PM
  4. Shimano front derailleur compatibility
    By ivko in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-28-2011, 05:55 AM
  5. Vintage XTR - front derailleur: FD-M900 compatibility
    By Erik_A in forum General Discussion
    Last Post: 08-02-2011, 03:36 PM
