Results 1 to 6 of 6
    Reputation: u4ic's Avatar
    Wrist pain - Just purchased Cannondale Rush 400
    Hi All,
    Just purchased my first decent bike. I have been riding a Dept. Store Mongoose w/ full suspension. My only complaint so far is the pain/discomfort in my wrist. I never had any pain when riding the goose, so I'm guessing something needs to be adjusted? I'm not sure, but I get the impression that maybe my handlebars need to be raised to shift my CG back on the bike? Also, the grips feel to small and hard for my hands, hard to hang on to once hands get sweaty. I'll probably get gloves, but I was wondering if the grips should be replaced.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Could be handlebar adjustment, levers relocated, grips & just need gloves. It's fairly simple to adjust bars & controls, loosen the bars & set them where they feel comfortable. Next loosen the controls & adjust to be comfortable, controls you can make snug so you can ride around the neighbor hood & rotate them till comfy, then tighten. Check out the ODI grips, the Yeti ones are very cush.
    http://www.odigrips.com/mtb_yeti_lo.htm
    Hey dogonfr, thanks for the advice. I picked up some mechanics gloves from Home Depot on the way home and it made my ride much better. Will try to tinker with handlebar and component placement today. I'm pretty sure the brakes levers need to be rotated down because I'm have to slightly lift my wrist when braking. Thanks for the link to the grips, those look a lot more comfortable than my current setup.
    Jan 2005
    Hope it works for you, if not hollar back & i'll bang my head on the wall & see what falls out next. I have thumb pains & sometimes wear EVS wrist brace for comfort. The one i use is the WB01.
    http://www.evs-sports.com/products/?prodCategory=8
    I just bought a scalpel 1000, and I'm getting the same thing. It has flat bars, though, do you think switching to a riser would help at all? It's not immediate, more like on a longer ride, my thumb starts to go numb and I get pain in the wrist. It sorta feels like the handlebar is too narrow It's really the only complaint I have with the bike though, assuming my ass gets used to the seat
    Jan 2005
    Quote Originally Posted by Evisr8r
    If you are leaning on the bars that can create problems. Look to see if there are shims on top of the stem if there is remove the stem & put the shim under it. Be shure the controls are in a comfortable possition next would be a riser bar. Funny coment about bar width, i am helping a 17 year old XC racer & he wore the grips on the outsides & said he would like a wider bar for comfort & to open his lungs for better breathing. Check out the WTB seats they are very comfortable.
    http://www.wtb.com/index_flash.html
