Will my idea work?
Today my dad was feeling generous and said that I can get my new bike in late September/early October. (Has to do with passing a test) I've decided to get a Santa Cruz Chameleon frame, and I was wondering if it is possible to transfer all the parts from my completely stock Trek3900, and over time I'll upgrade. Is this possible if I get my LBS to do it.
(since all components are the same size right?) Because the Chameleon Frame I want will be a bit bigger in size.
BTW, to upgrade to disc brakes, all I'd have to do is get new rims that are disc compatible right?
most of your trek components will transfer over to the santa cruz. the bottom bracket, seatpost, and front deraileurs are things that might not fit the chameleon. its probably not worth putting the trek fork on the chameleon though. does the chameleon have v-brake bosses on the frame?
if you want disc brakes you will need disc hubs and disc rims. you can get a deore disc wheelset pretty cheaply. it would probably be more cost effective to get mechanical disc brakes, they usually require less maintanence and you can use your stock v-brake levers.
- You may not post replies
- You may not edit your posts
Forum Rules
