Results 1 to 16 of 16
    May 2014
    Will this fork fit?
    Will this fork fit a 2014 trek X-cal 6?
    Used Fox F29 RLC FIT 29er fork. G2 offset. 1-1/8 inch diameter by 7-1/2 inch long steerer tube.
    Looks like I can get it cheap and I don't want to spend a ton of money because I might upgrade to a different bike soon but I don't think I can take another ride on the junk stock fork. haha
    Aug 2013
    Your frame has non-tapered headtube, so youŽll need a fork with straight steerer.
    May 2014
    It is a 1 1/8" straight steerer tube... I'm pretty sure it will fit. Taking a rough measurement on my bike the 7-1/2" tube looks to be long which will be easy enough to cut down.
    Any other reason it might not fit?
    Aug 2013
    Nope, difference between cheap Suntour and Fox is going to be huge
    Fat-tired Roadie
    Nov 2007
    Sounds good. Sounds like you're comfortable with the idea of not getting money back out of it if you move to a new bike.
    Do it.
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    Go for it.
    Reputation: velo99's Avatar
    Apr 2014
    Sorry for hijacking but I don't think of these things until I m reading a similar thread.
    Can you cut a fork tube with a plumber type tubing cutter?
    Question #2 Would you put a 300.00 fork on a Jamis Trail X 3.0 frame? It would be the first major upgrade. Other option is a coil over for 200.00
    Anything is better than Spongefork Gilapants.
    Yes
    May 2014
    Thanks for the help.
    What is a fork like that worth used in good shape?
    Fat-tired Roadie
    Nov 2007
    Few hundred, I think. EBay closed listings can give you a good idea. I think they depreciate fairly similarly to a complete bike.
    Reputation: Shakester's Avatar
    Jun 2012
    Quote Originally Posted by velo99 View Post
    As dirt devil already answered, yes, but after you do cut it you may want to file the edges down. Use a dremel if you have one. A pipe cutter pancakes the edges slightly and not only does it make it harder to slide a headset over it, but it can also get pretty sharp.
    I like Jamis Trail X frame so I would, but its really up to you.
    Reputation: Nubster's Avatar
    Don't cut it too soon though. Ride it long if you can unless it's way too long. That way you can make sure that you have a good fit on the bike before cutting. If you cut first, ride later, you may find that you wish it was a little longer to raise the stem up a bit.
    And for #2, sure, why not. Nothing wrong with improving your current bike. If/when you sell that bike, you can take the fork with you to your next bike if it doesn't have a great fork. Or sell it with the Jamis to increase the value a little.
    Kona Big Unit SS
    Kona Private Jake SSCX
    DiamondBack Release 3
    Apr 2014
    What length are they normally produced in? Seems I have been seeing 7 1/2" a lot as I scour the internet for fork deals.
    May 2014
    Update,
    Got the fork, put it on (super easy btw) and took it for a rip tonight on a very familiar 10 mile single track loop. Started with the recommended setup and only had to add a few clicks to the low speed compression to get to my liking, for now at least. Well worth the money. It holds a line so much better and 1/4th of the way through my confidence went way up and was going down and through stuff easily that was making me pucker up pretty hard before. Maybe my favorite part is that there is no more embarrassing creaks and cracks like the front end is gonna come apart... They should put a warning sticker on a stock fork like that,,, oh wait there was. lol
    Fat-tired Roadie
    Nov 2007
    Awesome!
    Apr 2014
    Sweet. Glad it worked out for you. Can't wait to get mine.
    Ride on bro.
  1. Lauf Trail Racer Fork. The lightest 29er suspension fork ever?
    By Shalom in forum Shocks and Suspension
    Last Post: 06-11-2015, 05:45 AM
  2. Replies: 5
    Last Post: 02-18-2014, 07:12 AM
  3. Replies: 3
    Last Post: 02-17-2014, 05:34 PM
  4. OPINIONS: Aluminum rigid fork or suspension fork for 9yr old's bike?
    By dragbike in forum Families and Riding with Kids
    Last Post: 05-09-2013, 05:06 AM
  5. Salsa Cromoto 26" fork to replace 100mm travel fork
    By rth009 in forum Shocks and Suspension
    Last Post: 01-03-2011, 09:51 PM
