Why go tubeless?
Printable View
  • 11-17-2012
    shibiwan
    Originally Posted by TiGeo View Post
    I can't believe all the back and forth about rolling resistance and the theory of it. Stop reading this crap, convert them to tubeless, run lower pressure than your are used to, and go for a ride. Then you can make your own opinion of whether or not you think it works. This reminds of me of all the theorizing that goes on about 29ers, whether they roll over things easier, whether they climb easier, whether they are faster, blah blah blah. Just buy one and ride it. If you like it, great, if you don't, sell it and go back to your 26er.
    Thank goodness. It does look like we are over analyzing this. :thumbsup:
    -S
  • 11-17-2012
    wmac
  • 11-17-2012
    swcreates
    Originally Posted by Bill in Houston View Post
    you're already going from 8speed to 10speed for reasons that make sense only to you. why ask us about tubeless?
    sounds like you are a guy with some money to spend who likes to have nice stuff, even if he doesn't necessarily know why. all the guys like you have tubeless. all of them say it is way superior to tubes, even though they can't exactly explain why.
    it sounds like other people do all the work on your bike, so that is something in favor of getting tubeless - if you don't have to do the work yourself and have the money, why not get it?
    i hope it doesn't sound like i'm raining on your parade. i guess i'm just saying that only you can decide, and a lot of guys like you have gone to tubeless. whichever way you go, i hope you are happy and get to ride it plenty.
    I'm going from 8 to 10 because I got a screaming deal on parts. And actually I did all the upgrades myself.
    After reading all the feedback, I'm thinking just sticking my my current setup and run tubes. The extra money for a tubeless set up doesn't seam to make since. Thanks for all the feedback guys!
  • 11-17-2012
    CSC
    comment deleted
  • 11-17-2012
    4Crawler
    Originally Posted by Saul Lumikko View Post
    Increased traction doesn't necessarily mean increased rolling resistance. Traction stops the tire from slipping, but rolling is a different thing.
    When going over irregularities, a tire without a tube will conform to the changes more easily, so it's more noticeable than on hard and smooth surface.
    006_007, my observation could be placebo, because if the effect was as big as I perceive, it should be easily replicated in an empirical test. However, I think if you rolled as far with a tubeless setup - which is lighter and thus has less freewheeling effect - you already witnessed a lower rolling resistance. (Whether this can be noticed when riding is a different thing entirely.)
    I recently converted my cross bike to tubeless running 700x40 touring tires.
    - DSCF1446
    I found that indeed I had more traction and less rolling resistance at the same time. I no longer slip on the same gravel road climb that I used to w/ tubes when standing and pumping he pedals hard. Likewise I have seen like 1 - 1.5 MPH faster rolling speed on a couple of test rides on the same roads. I can feel it is easier to pedal for the same speed on pavement and this is with running 28psi tubeless compared to 35-40 w/ tubes. I had been running a pretty heavy tube in the tires. And this is with the exact same tires tubes and tubeless.
    Hardest thing I have found so far is fighting that old urge to "pump those tires up", I am used to 50-70psi in my touring bike and 90-100psi on my road bike.
  • 11-17-2012
    wmac
    Originally Posted by CSC View Post
    comment deleted
    Why delete? We all saw it. It was good.
  • 11-17-2012
    CSC
    - DSCF1446
    Not relevant data unless you used the same tires. Lighter tires with a new tread pattern with no tubes, and a bit of the good old placebo effect will do wonders for climbs.
    And wmac...I deemed the conversation closed, as the OP made a choice (as it turns out my comment was correct...I just thought it was a little useless to have it up after OP said effectively the same thing).
  • 11-18-2012
    TiGeo
    Note that my post could be used to solve:
    wide vs. narrow handlebar threads
    mechanical vs. hydro brake threads
    FS vs. HT threads
    650b vs. 29er (any wheel size) threads
    The list could go on and on!
  • 11-18-2012
    wmac
    Hey TiGeo: There is an "Unsubscribe" button, you know. :)
  • 11-18-2012
    Saul Lumikko
    A flat tire on or off road does increase rolling resistance. I guarantee it.
    Of course it does. I don't think anyone in this thread disagrees.
    A flattened mud tire may be faster at getting through mud than a pumped up tire, but it still has more rolling resistance than when inflated to its "Goldilocks" psi.
    Well, "flattened" is a relative term. If by "Goldilocks" you mean optimum pressure, then I agree - and it will be faster too.
    Originally Posted by wmac View Post
    CSC, you are right. Rolling resistance is rolling resistance. The terrain doesn't magically change the rolling resistance physics. Running lower pressure is higher rolling resistance regardless of the terrain. The same bike with the same rider with the same tires is going to have lower rolling resistance at 40 psi vs 25 psi regardless of terrain. The difference is the energy expended to make it from point a to point b on various terrain with 40 psi vs 25 psi. Running lower tire pressures is an argument of efficiency, not rolling resistance.
    As someone who rides on streets and roads and off-road trails, I could not disagree more strongly. Rolling resistance happens between the tire and surface, and both of these have an equal part in the whole equation.
    If we push a bike on a smooth polished surface, maybe glass, we'll indeed get the lowest resistance with the tire pumped as hard as it can take.
    Step out to the real world to as much as pavement, and you'll notice vibration with the bike set up for a glass surface. Reduce the pressure a bit to make the tire conform to the irregularities and the rolling resistance will be reduced as well.
    Asphalt in a bad condition requires again a slight drop in pressure to optimize rolling resistance.
    When riding on a trail with rocks, roots and other bumps, lowering the pressure even further will reduce rolling resistance.
    Of course one could ask the question "lower than what?", and it's a good question. The "lower your pressures for rougher conditions" is not a suggestion to go below the optimum pressure, but find the optimum one. Higher for harder and smoother surfaces, lower for bumpier and softer conditions.
    I mean, no one would run 15 psi tubeless, right?
    Been there, done that. It increased the rolling resistance a bit, while traction only got better. Depends on a few things - I weigh 72 kg (158 pounds) and have 21 mm (inside width) rims with 2.35 29er tires.
    Do note that I'm not saying people should run lower pressures, but instead find the right one for their weight, tires, trail and riding style. In some cases lowering the pressure will reduce rolling resistance, but going too far will make it increase again.
  • 11-18-2012
    TiGeo
    I can't help it.
  • 11-18-2012
    wmac
    "Rolling resistance is the energy that is lost when the tire is rolling and the main reason for loss of energy is the constant deformation of the tire."
    Source: Rolling Resistance | Schwalbe North America
  • 11-18-2012
    006_007
    Originally Posted by swcreates View Post
    I'm doing some upgrades to my bike, and I'm looking my options for wheels. I'm to the point know where I'm looking at tube and tubeless rims. What would be the main reason for going tubeless?
    I'm sure it's a simple answer, but this noob needs some help.
    Dayum, so much for a simple answer. 3 pages rambling on about rolling resistance VS pressures. At least there were no charts involved. Charts are bad. Unless its a pie chart. Pie is good.
    OP please do not hesitate to post again in the future. We have pie.
  • 11-18-2012
    osokolo
    this is what matters... rolling resistance is often used in the same sentence with average speed and traction.
    lower pressure tires may have higher rolling resistance (dependent on the design and thread - in some cases the difference is INSIGNIFICANT) but in most cases - off road - lower resistance means higher average speed OR less energy required to cover the distance between point A and point B.
    lower pressure tires better conform to the rough nature of off road trails where the rubber requires less energy to absorb the roughness as opposed to the rest of the bike - suspension, frame, seat post, handlebar etc...
    always added benefit is traction - which increases with softer tires.
    about the only negative side is messy setup (non ust) and often tire changes - which i addressed by owning 2-3 sets of wheels - to address different riding/racing conditions (mostly racing). if you do not change tires often - this negative side may be easily ignored.
    tubeless setup, in my case, is superior to tubed - for above mentioned reasons.
  • 11-18-2012
    osokolo
    I can't help it.
    what is wrong in learning from other people's experiences and mistakes...
    saved me a lot of money...
  • 11-18-2012
    CSC
    Which is why I keep referencing the tire's "butter" or "Goldilocks" psi zone. We are arguing about saying the same thing. Look over my posts if you disagree.
  • 11-18-2012
    Nickt30
    conforms to trail surface
    Tubes hold the tire round at the bottom.
    Tubless allows it to conform to the surface giving you wonderful grip.
    As for rolling resistance....dont run super low pressures.
    I run a 29er 2.35 with tube 32psi in rocky north jersey.
    I switched to tubless and run 28-30 psi. Ride wt 200lbs
    Incredible grip performance.......
    When i run below 28 it feels sluggish.
    At 28-30psi i have never flatted, burped or had trouble mounting them for an entire season.
    I have even run none ust tires on none ust rims.....if they snap into the bead then it is a good candidate for tubless.......stans tape & fluid.
    Go tubless for traction.
    I only read a few posts that hit on traction.....but this seems to be the reason that i think you should switch.
    For me it was not weight or supper low pressures.
    After a season on them switching back to tubes does not feel as confident on tricky terrain.
  • 11-18-2012
    Bill in Houston
    Awesome.
  • 11-18-2012
    Saul Lumikko
    CSC, seems that there was a bit of miscommunication and semantic differences at play. I also think we agree on almost everything with regards to tire pressure.
    Just one thing I call to question, and it's the assertion that higher pressure always means lower rolling resistance. In my opinion it is only true on a perfectly smooth surface: tire deflection is a major contributor in that case. However, if you ride a rock hard tire on asphalt that has seen its better days, the rough surface under the hard tire will result in a higher rolling resistance, while the same tire with a bit less pressure allows the tire to soak up the bumps.
    Here's a good post summarizing what I'm talking about with original sources listed: Road Bike, Cycling Forums - View Single Post - Reduced air pressure for "reduced rolling resistance"??
    In short, I acknowledge that dropping the pressure too low will increase rolling resistance. Quite often tires roll better with a bit higher pressures than lower, but there is also an upper limit, a point where increasing pressure ceases to reduce rolling resistance.
    Edit: A couple links and quotes.
    Bicycle Tires and Tubes
    "In practice, riding surfaces aren't perfectly smooth, and overinflation actually increases rolling resistance, due to vibration."
    Rolling Resistance and Tire Pressure
    "Wider 28-mm tires are as fast at 85 psi as they are at higher pressures."
    "At 130 psi (9 bar), the narrow Clement Criterium rolled slower than it did at a more comfortable 105 psi. The wider Clement Campione del Mundo rolled slightly faster at 85 psi than at 105 psi."
  • 11-18-2012
    wmac
    Good study. A couple thoughts:
    1. This study was conducted using road tires.
    2. This is interesting: "Riding your tires at the “optimum” pressure optimizes both comfort and performance. At lower pressures, you roll slower. At higher pressures your bike is no faster, but much less comfortable. Our tests of the same tires at various pressures determined the
    optimum pressure for each tire for our rider/bike combination." Duh. The question is, how to determine optimum tire pressure for MYB tires. They suggest a method, but not sure if it pertains to MTB tires.
    3. I did not find anything in that study that contradicted anything I've written in this thread.
    I'm beginning to agree with you guys, WTF are we arguing about?
    Why tubeless? Reduce/eliminate flats and have wider range of tire pressure adjustment in order to find "optimum" tire pressure for trail, rider and style.
  • 11-18-2012
    CSC
    Yes. The "butter zone" takes into account the upper and lower bounds of optimal tire pressure for a given tire.
    A rock hard tire will ride over every single bump, effectively forcing the bike to travel a further distance than if the tire rolls "through" bumps. Think about tens of bumps, each causing millimeter rise and fall in the bike every second...over 20 miles, this will add up to quite a bit of extra distance traveled...hence the advantage of knowing the optimal tire pressure for a given tire, which will reduce this seemingly trivial but incredibly wasteful up-and-down motion of the bike...which also tires out the rider, by the way.
  • 11-18-2012
    Saul Lumikko
    1. Yes. The info from Schwalbe (who you quoted earlier) is also about road tires: Inflation Pressure | Schwalbe North America
    "The following applies for the road: The higher the inflation pressure the lower the rolling resistance of the tire."
    I think most (if not all) principles can be applied for MTB tires as well: slick is faster, hard is faster - up to a point where you don't gain advantage and start reducing performance.
    A quote from wmac earlier in this thread: "If you are on a surface with a lot of bumps, lower pressure will require less energy to cover the same distance compared to higher pressure."
    This is precisely what I'm also trying to get across. It seems I call this reduced rolling resistance, you call it improved efficiency, for CSC it's something achieved by a "butter zone" pressure. We agree on the practical side, but differ in semantics. I'm happy with that.
    As for a method to find the right MTB tire pressure for yourself, I suggest the following:
    1) If you only ride for your own amusement, try out different pressures and use what feels best.
    2) If you race, time your laps on an actual trail to see which pressure allows you to ride fastest.
  • 11-18-2012
    Nickt30
    just an additional thought
    i truly believe that using a tire pressure with in the range of the recommended pressure listed on the tire is crucial. The side wall is designed to hold strong between those pressures and support the volume of the tire under the rim. Below it and the side wall will collapse and roll out from under the rim causing a wash out. Especially true on a tubeless when there is no tube to help the tire's side wall from folding. The upper limit is more for rim/bead interaction.
    In the Beginning…
    Tubeless officially debuted for mountain bikes in 1999. Mavic, Michelin, and Hutchinson worked together to create a new standard for mountain wheels and tires called Universal System Tubeless, or UST. Under this new standard, the tire’s casing is thicker all the way around – essentially transferring the weight and material of an inner tube on to the tire itself.
    You need the proper inflation to support the volume of air and keep it under the rim.
    this is actually very cool for determining a theroretical tire pressure
    Recommend Tire Pressure « Vittoria
  • 11-18-2012
    wmac
    Saul: Agree, agree, agree. I think the point I was trying to make was that having a higher rolling resistance (lower pressure than butter zone) is a good strategy because many trails have drastically differing terrains and you have to make trade offs based on what is going to net you the greatest efficiency. So, a course that is mostly flat, hard packed with little variation may be best. Change that course to very technical rocky sections that require high traction and grip and you may be better off with lower pressure. Hence, ride the highest pressure possible while maintaining optimal traction in the most difficult sections - just like you also mentioned :)
  • 11-18-2012
    Z4good
    I'm sold!! I'm switching to tubeless!!! I never realized this could be so involved, but after reading all these posts I feel I have a better understanding, and can't wait to give it a try. Thanks
  • 11-18-2012
    alphazz
    This isn't scientific. I've had two flats with tubes on my new fatbike. Today, my front tire was tubeless, the rear has a tube. I've pumped up my rear tire twice. My front tubeless tire was flawless.
  • 11-18-2012
    wmac
    Good luck Z4!
  • 11-19-2012
    Saul Lumikko
    Just one more thing, in the spirit of Columbo. Couldn't resist...
    I think we went a bit off-topic with the tubeless thing when one benefit of tubeless was said to be the ability to run lower pressures. From there it went to pressures without regards to tube vs. tubeless.
    We overlooked the fact that the comparison wasn't between the same setup with a higher and lower pressure, but rather "with a tube, higher pressure" and "tubeless, lower pressure".
    I would argue that removing the tube has a positive effect on rolling resistance, which may be negated by lower pressure, so one hypothetic outcome would be "less pressure, same rolling resistance". I.E. when you go tubeless, you can run lower pressures for the traction and smooth ride without increasing rolling resistance compared to your old setup with tubes.
  • 11-19-2012
    wmac
    Great point Saul! For those lurking noobs - the reason this is the case is because it takes energy to deform a pressurized tire and tube. It takes energy to pinch a tire and tube, right? Same thing is constantly happening when you are riding. As you ride, the tire and tube has to constantly change from round to flat to round as it passes over the contact patch. When you eliminate the tube, you energy the loss that happens when the tube goes through that cycle.
    So, it's true when converting the same tire with and without tubes. It might not be the case if you go from a standard tire with tubes to a UST tire because of the stiffness of the sidewall, etc. This is why lighter tires often have lower rolling resistance- because it takes less energy for the casing to go from round to flat to negative arc (for roots and rocks) and back to round.
    This principle also explains why it is more difficult to push that dolly with low pressure tires compared to higher pressure. But, put a stick in front of that Dolly's tires and the force that is required to push the dolly over the stick is lower with lower pressure tires compared to higher pressure tires. The "butter zone" is to minimize the force required to move over smooth and irregular surfaces.
  • 11-19-2012
    osokolo
    good summary wmac... that pretty much ends the discussion...
  • 11-19-2012
    CSC
    Though again, deflate those tires too much, and you again start increasing the effort required to overcome the "stick" due to all the extra tire deformation going on. Not too hard, to too soft, just right. :thumbsup:
  • 11-19-2012
    wmac
    CSC - Yep - You're right!
  • 11-20-2012
    Saul Lumikko
    We've reached a point of 100% agreement. This is too rare on the internet.
    I got a notification: "You must spread some Reputation around before giving it to wmac again." :D
  • 11-20-2012
    wmac
    :) I think I hit everyone a while back :)
  • 11-23-2012
    Visionist
    Tubeless definitely sounds a lot better
  • 11-25-2012
    SlickWilly8019
    Boy was it ever Worth converting...Sorry I waited so long.
    Well after posting here about converting to tubeless, I took the bike for spin on Thursday out in the desert and I ran threw a thorn patch where I picked up 4 punctures in the rear & 6 in the front tire. If I had been on tubes i would have had to change the tube on the front and use 1 patch kit to fix up the rear. Otherwise I would have had to walk up to the trail to a road and call for a ride. Went for a another 10 mile ride today, I never aired up the tires since they were as firm now as 4 days ago.
  • 11-26-2012
    Paco1driver09
    tubless is good excellent
    the tubeless is the future
    no more problems to remain on the ground Nee itching, mqggior comfort and response in the guide
    more grip
    is almost full. the top is tubular but only for those who have lots of money and racers
    the tubeless than the tubes is another world, a huge step quality
  • 11-26-2012
    moofish
    Ok Ill start by saying yes Im a noob and may not have a valid opinion as I have never run tubeless but noone here has mentioned rotational mass.If you run circus wheels and you save weight in the tyre you dont just save on rolling resistance(or not) but the rotational mass will be much less, meaning that pedaling will be easier and the bike will have less momentum. Maybe it would make a 29er pedal a little more like a 26"
  • 11-26-2012
    wmac
    Valid opinion. Discussed in thread above. Tubeless 29 vs tubeless 26 is same as tubed 29 vs tubed 26. Minimal weight loss performance gain.
  • 11-27-2012
    Saul Lumikko
    The weight reduction doesn't make pedaling in itself easier, but acceleration and climbing benefit from reduced weight.
    As for a 29er pedaling like a 26... There's way more to that. I've run my 29er with tubes before going tubeless and my 26" also tubed and tubeless. None of the four setups compare to each other. The size difference makes way more of a difference than tubes vs. tubeless.
    I'll just say tubeless offers several benefits no matter what size tires you like to run. Even my road bike is tubeless. :)
  • 11-27-2012
    RobinGB
    what kinda upkeep do you have with tubeless? how long before the sealant loses it stick, does it dry out and lose it integrity inside the tire over time. Do you need to add more sealant ever few rides?.
    I keep thinking about switching because most of my tubes are more patch then tube, im 250ish in full kit 240 for my average ride. But its rough rooty and rocky and im not the best rider int he world so i miss alot of kicks and case stuff all the time ending in lots of pinch flats.
    The tubeless system seems a great idea, but it also seems like it could be a bit of a pain int he ass. Get a flat ont he side of the trail and now you have tubeless goo to deal with aswell as allt he mud and dirt.. i dunno
  • 11-27-2012
    wmac
    Change it out every 3-6 months. If you cut a tire on the trail, the sealant likely spewed out already trying to seal it. It has to be a very big cut for this to happen. Just clean the area and put a patch on the tire and put a tube in like you would with a normal flat.
  • 11-27-2012
    RobinGB
    how is the DT swiss tubeless conversion kits compared to stans? the price is a little bit better and i would imagine things would be better fitted for the rims i have. Is tubeless brew pretty much the same through everyone?
  • 11-27-2012
    wmac
    Not sure - I only use Stan's with UST rims. There are some tire/rim combos that are better than others.
  • 11-29-2012
    poolnikov
    I use tube of DH ande tyre of DH, Maxxis Minion front and rear, and never lost air in my wheels
  • 12-23-2012
    DennisF
    Someone (I know who you are :)) gave me negative rep for my first post to this thread, and I want to comment.
    cars with tubeless tires get better gas mileage? compared to all the cars out there with tubes? nice try
    My point exactly. That's one reason why tubed auto tires are a thing of the past thankfully.
    I have probably been around a little longer than the commentor. While tubeless tires were pretty much standard even when I was a child, there was still a discussion of tubes vs tubeless for cars, and there were a few old-timers who liked tubes. I remember my high school auto shop teacher discussing the advantages of tubeless, and he mentioned cooler running and better gas mileage. (Radials have the same advantages BTW).
    Anyway, give it another 10 years, and I will surprised if tubes aren't pretty much a thing of the past in better-than-department-store bikes. If'm I'm wrong, you can give me more negative rep. And, the people who think they roll noticibly easier, while I don't agree, have some evidence to back them up.
  • 12-23-2012
    wmac
    The Myans were right.
  • 12-23-2012
    Millfox
    Originally Posted by DennisF View Post
    Anyway, give it another 10 years, and I will surprised if tubes aren't prettymuch a thing of the past in better-than-department-store bikes. If'm I'm wrong, you can give me more negative rep. And, the people who think they roll noticibly easier, while I don't agree, have some evidence to back them up.
    I doubt that. First of all it's a messy thing to do. People don't like to deal with mess.
    Second of all: It can get time consuming with all the shaking, and turning and soap water and stuff. You can argue that you can swap tubeless tyres in 15 minutes, but that's your skill with your specific setup.
    Third: It's more expensive. Maybe not that much, but for many people that take cycling more as an occasional hobby than a passion it can be a valid factor.
    I think that your prognosis is a bit... optimistic.
  • 12-23-2012
    Saul Lumikko
    Techniques, tools and components develop. Once technology becomes more common, prices drop. Tubeless will increase in popularity as a result.
    That said, tubes will probably remain the easier way and some people can't tell the difference (or the convenience outweighs the slight advantage). As opposed to cars, end users change tires a lot more so ease of installation is a more significant factor.
    Not all people (or even enthusiasts) are willing to go that far for some performance. This applies to tubulars as well.
  • 12-23-2012
    DennisF
    You both make good points. However, I think a lot of the resistance to tubeless is just the momentium that tubes have, like it probably was when tubeless auto tires came out. People often loathe change.
    I may be full of it, but I think that once you learn how to deal with tubeless, it is currently as much about convenience as performance -- you can schedule maintenance of your tires at your convenience rather than deal with enroute failures. It doesn't take much to pop the bead and inspect the sealant, adding if necessary. I am trying glycol-based goo. It cleans up with water and is way less messy than Stans. Probably not as good at sealing holes, but from every indication so far, way better than tubes. No failures yet. And no worries about a noob like me pinching a tube while installing it.
    Reading here and looking at the healthy number of posters who try a good TLR system and like it and stay with it, and the few that go back to tubes, I'd say it's catching on.
    The technology is still in its early stages and there is room for improvment. Imagine if the sealant would last for a year and bikes came from the factory already set up for tubeless. This is not too far-fetched. Heck, there are currently rims that don't need goo. That is a problem if you get a puncture, but if you could plug holes without dismounting like you do your car....
    Anyway, we'll see!
