Results 1 to 6 of 6
    When to replace tires??
    I have around 450 miles on my bike and noticed the tires are starting to wear. When is a good time to replace them? Should it be a once a year thing or a mileage thing or should I just go by the tread on them?
    I think ,correct me if I'm wrong , 50% centerline tred loss and/or loss of side knobbies.
    ps.aviod skidding .Can lead to premiture wear...
    I wear out the rears pretty quick, no hard and fast rule, generally I get pissed of at the lack of traction, and get a new one.
    Quote Originally Posted by Musichead13
    When you have to ask, it's time to replace.
    Tires are cheap enough and the feeling of new tires is always great and it's way safer to keep yourself wrapped up in only the best rubber
    Killer b.
    Reputation: The Understater's Avatar
    Most riders end up with a bunch of different tires for different tracks or conditions. I will put really badly worn tires on my bike if all I want from them is to roll fast. If I want cornering grip, I generally use a newish set. You will wear out the rear center treads faster, but if cash is an issue, then swap them around and wear out the other one. Unlike a car, riding on worn tires isn't much of a safety issue. Tires are a bit like undies. Some like boxers and some like briefs. Buy a new set if you want to try out different handling characteristics. I read the review section here before buying something new. Just remember you get some very extreme opinions on this site, so go with the majority opinion.
    Good luck
    Posting on the basis that ignorance shared is ignorance doubled.
    Replace your tires any time you have an extra $50.Actually, when you notice a decline in performance,or any damage in the sidewall it's time for new shoes. Expect 2:1 rear/front.
