Results 1 to 15 of 15
Thread: Wheelies
    Wheelies
    I just bought a new gt zaskar expert . When I climb I can not keep the front wheel down Even on small climbs I have to stand and lean foward. Any suggestions???
    thanks
    Ride the dream
    Reputation: EnglishT's Avatar
    Few questions....
    How steep a climb does it take?
    Is everything stock? (Important question - especially on seatpost and stem)
    It does not take much of a hill at all for it to take to the air. I can copensate with body position on smaller stuff but I have stop on any slighty callenging climb. yes all stock
    Ride the dream
    How tall are you and what size frame are you on?
    (sorry - just wanna be sure that its not equipment before it ends up on technique questions)
    large frame. I am 6'1"
    Generally the first thing to do is lower your torso towards the top tube, if that's not enough, try scooting all the way to the front of the saddle so you are sitting on the very nose and keep your torso down.
    Standing can get your weight forward and give you a bit more power but it is a bit harder to keep your CG in the sweet spot that gives you enough weight over the rear wheel to keep traction and enough weight over the front to keep it down. On a smooth climb it works but throw in some roots, big rocks, etc. and it gets tough to finesse it when standing.
    Also, sitting you can put the power down more smoothly than standing so you avoid the bursts of torque that want to lift the front wheel or break traction.
    Ride the dream
    Well put.
    Another thing (personal choice, but works for me) is to whack the saddle a bit further forward on the rails (and it allows you to ride further forward on it aswell if needed).
    This puts your weight forward on seated climbs.
    It also has the added bonus of giving more space (makes it easier) to ride off the back on really steep descents.
    American Icon
    Reputation: Fender Roads's Avatar
    A few ideas...
    1. Slide forward on the saddle more (on the nose of the saddle). I have a large freeride bike (tall front end due to the fork) and by sliding forward on the saddle, I can keep the front end down on 95% of all trail rides.
    2. Lean forward more into the bars but stay seated. I know it sounds basic, but whenever I hit a tough climb, that is the first thing I do to keep the front end from wandering.
    3. If that doesn't work, try swapping out a different stem. Maybe something with zero degree rise? A LBS should be able to help you out.
    Why not just take the hill on your back tire? Way more impressive than making it on two.
    Seriously though, my first question would be how much riding experience do you have? Making steep hills without wheelies and without losing traction can be very difficult. Many times, experience and feel are the two most important part of cresting steep, technical hills. My advice is largely the same as everyone else who has posted. Good luck.
    Thank you all for you input but I ride the same trail 3 nights a week. my last bike was an old cannondale f-900 it never gave me this problem. I sold it to get this bike so I can not use it to match riding position. I am not a great rider but I know I can do things better on other bikes than i can on my new zaskar. I just need help getting her dialed in
    Ride the dream
    It just takes time to get it to feel exactly how you want... the cockpit length may not be exactly the same - its all about complimenting the angles on the frame you have now.
    As a starting point - do you feel too stretched out right now?
    Moving the saddle forward on the rails would help keep the weight forward on seated climbs and would bring your riding position more upright.
    Also - how does your steering feel?
    If it feels a little fast for your liking, a longer stem might work wonders (more weight over the front axle = more pressure to hold the tyre to the ground.
    If your steering feels perfect, I would try to sort it with the saddle position alone.. If your steering is a little quick for your liking you could try method number 2 also.
    moved seat foward and going for a ride. I don't know about a longer stem guys I'm already on 110mm. 120mm just looks huge to me. Is there a weight limit on a 120mm? What would be the result of flipping my 110mm stem from +6 to -6 deg?
    Reputation: snowdenn's Avatar
    someone taught me to pull down on the handlebar on particularly steep climbs. instead of pulling back which helps raise the front wheel, pulling down helps keep the wheel from lifting. like rowing, and time each pull with pedal strokes. might help.
    Ride the dream
    Quote Originally Posted by patada
    Yea 110 is already pretty long. 120 or 130 might make alot of difference though.
    That said - if youre a big fella, its gonna have to be very stiff (read, heavy of expensive) for you not to feel it flexing.
    Flipping it would also put more weight on the front wheel - because your body is leaned further forward and so your weight is further forward.
    Personally, I wouldnt change too many things at a time - if you do, you wont know which one has had what affect if you find you dont like it (or if you find youve gone to far, choosing which to reverse is harder).
    Can I just ask - did your bike really come stock with a 110mm stem?
    I mean, thats quite long - more often its the LBS that would put on a stem like that to "make it fit" if it doesnt quite already.
    (Just asking)
    Are you in your granny ring? I never could figure out how to climb in it, so started leaving it in the middle ring and standing on climbs. Didn't take long before I gave up on gears all together and went SS.
