Results 1 to 8 of 8
    Oct 2016
    Wheel Swap questions
    So, looking to change my wheel as the current wheels I have are a bit beat and dented.
    If I were to swap to a set of wheels that have the "same specs" as what I currently have are there any other considerations that I would need to be concerned about?
    Do bike wheels have an offset? Is this a major factor?
    Will I need to get new axels?
    Front wheel: 27.5 15 x 100
    Rear wheel: 27.5 12mm x 142mm
    Brake rotors: 6 bolt
    Mar 2015
    As long as you have those measurements, the other concerns are:
    Weight
    Internal Width of rim
    Tubeless ready rim
    POE- points of engagement and number OC clicks per rotation
    Oct 2016
    Quote Originally Posted by FJSnoozer View Post
    Weight
    Tubeless ready rim
    Thank you sir!
    Reputation: brent701's Avatar
    Sep 2012
    Weight
    Tubeless ready rim
    I'll add one
    Type of riding
    Too Many .
    Mar 2015
    And maximum weight
    since 4/10/2009
    Reputation: Harold's Avatar
    Also spoke count/type.
    A lot of pre-built branded wheelsets use some sort of less common spoke type (a simple straight pull with typical threading at the rim side is one thing, but you can get bladed spokes, proprietary nipples, threading at both ends, etc). My advice is to stay as simple and common as possible. Because when you break a spoke (it's a when, not if), the less common that spoke, the longer you're likely to wait to get a replacement and the more likely it is that you won't be able to get a quick fix at a shop when you're on a vacation. For that reason, I strongly recommend plain 'ol j-bend spokes. A lot of those pre-built wheelsets also use lower spoke counts to shave weight. That might be great for racers looking to shave grams, but for those of us who just like to ride, it's not so good, as it usually allows for a flexier wheel. Stay with the standard 32 spokes per wheel unless you're especially hard on stuff, and then going with 36 might be a good idea.
    mbtr member
    Reputation: scottzg's Avatar
    Quote Originally Posted by ehfour View Post
    Get those things right and the wheels will physically bolt up.
    The other stuff being mentioned are factors to consider when buying new wheels, and it's a bottomless rabbit hole. Simply put you want 32 j-bend spokes and rims that are appropriate for the tires you wish to run.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Reputation: Mr Pig's Avatar
    If your wheels are taking a beating it suggests you ride hard so some stout wheels seem appropriate. If you have a wheel builder near you one of the best ideas is to have a pair built up. That way you can get exactly what you want.
    As others have said, nothing fancy. 32 or 36 good-old J-bend spokes, stout rims and a decent rear hub. Front hubs are all much the same.
  1. Replies: 1
    Last Post: 10-23-2013, 07:04 AM
  2. Replies: 7
    Last Post: 11-07-2012, 08:05 AM
  3. Replies: 442
    Last Post: 01-09-2012, 10:40 AM
  4. Wheel Swap... Chain Swap Too?
    By coopdad in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2011, 05:49 AM
  5. Frame swap: Want to swap my geared frame for your SS
    By bikewrench in forum 29er Bikes
    Last Post: 02-01-2011, 12:03 PM
Members who have read this thread: 47
