Results 1 to 3 of 3
Thread: Wheel Problems
    Oct 2013
    Wheel Problems
    Hi,
    I have a Trek 3700. I tried to take the chain guard off the wheel and took off the quick disconnect bar.
    Of course, I can't remember which way they went back on - I did it in this order -
    Quick connect handle - Spring - Nut (which attachs to the axle) - Circle Bit (inside rubber/plastic case) then wheel bearing
    On the otherside - End nut - Spring and axle.
    I followed the manual I downloaded - I tightened the wheel finger tight and then pulled the handle down.
    The wheel spins very easy without being tightened, but if its only fingure tight the wheel doesn't spin very well....
    Can you help me please.... I shouldn't have pulled the wheel apart, or the DVD, Fridge, TV etc...
    The quick release parts are nut, spring ,spring ,lever. Any chance that you tightened the axle nuts? The way to use a quick release is to havw the lever half way open ,tighten the nut finger snug ,close lever.Go the Park Tools, or Sheldon Brown for more info.
    Oct 2013
    Thanks,
    Yeah, I tightened the axle nuts... I think I broke the bearings. I opened them and the balls fell out, so I put them back in and replaced the axle. I can't open the nut on the lever side anymore... its on too tight. The nut on the otherside opens though.
    I'm an idiot...
  1. Any problems from using two different wheel widths?
    By LucidMTB in forum Wheels and Tires
    Last Post: 04-29-2013, 08:32 PM
  2. Stumpy Wheel Problems
    By laser beam in forum 29er Bikes
    Last Post: 10-04-2011, 03:51 PM
  3. E150 fork & Roval Wheel problems...
    By fbb in forum Specialized
    Last Post: 07-05-2011, 12:53 PM
  4. trek top fuel wheel problems!!
    By smokeuu in forum Wheels and Tires
    Last Post: 05-07-2011, 12:14 PM
  5. Paired Spoke wheel problems
    By cjn1014 in forum Wheels and Tires
    Last Post: 01-16-2011, 10:45 PM
