Results 1 to 8 of 8
    Reputation: joe_bloe's Avatar
    What's on your pre-ride bike checklist?
    Every ride, I do a quick once-over on the bike -- tire pressure, chain, brakes, spokes, quick releases.
    Last night, I got to walk out of the woods because of a new one -- left crank arm came off. Bolt was gone.
    I guess I'll add it to my once-over.
    It's all about the FSR!
    Reputation: Heavy Fluid's Avatar
    Mar 2011
    Petty much the same as your list.
    Sent from my Samsung Focus using Board Express
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    My pre ride checklist usually consists of "oops I forgot _____, hope that doesn't ruin my ride".
    I always try and make sure my chain is lubed and my tires are up to pressure. I'll usually squeeze the brakes at some point loading the bikes onto the rack simply out of habit so I'll usually find if they're messed up somehow. My bike has thru-axles and I don't take the wheels off except to service things but I would add in a QR check if I had them.
    I wouldn't bother checking crank bolts every ride unless you have a known issue but I would put the bike in the stand (or "stand") and check all the nuts and bolts every few rides. I usually try and do that once a month. If there's nothing wrong with the cranks, a monthly torquing will keep them tight and attached.
    1. Make sure the zipper on my pack is closed.
    2. Make sure the zipper on my pack is closed.
    Jul 2003
    Quote Originally Posted by joe_bloe View Post
    I pretty much check over the whole bike, pressure in the tires (fork and shock if air sprung, I do this by simply double checking sag and adding air if needed), headset (and anything else that has bearings for play roughness), stem bolts, brakes, levers, shifting, pedals, chain, cassette, chainrings, cranks, derailleurs (for both adjustment and damage), qr's, bolts, or TA for wheel security, spokes (checking for loose ones), pretty much anything that can come loose, and check the frame for cracks, damage, etc. This really isn't my pre-ride list, it's my post ride that I do during cleaning. I clean the bike and check everything after each ride. That way it's ready for the next ride. If it's a night ride or late when I get home, I'll do it the next day. That way the only thing necessary before the next ride is tire pressure, and wheel attachment.
    For my commuter bike it's a bit different, it gets ridden almost daily so issues will announce them selves in plenty of time to correct them usually. But I run through the above about once a week, or more often in crappy weather.
    But you are right, crank bolts should be part of your list. But I would recommend that it be done post ride. As I said earlier, then the bike is ready for the next ride. Finding out about a problem a few hours, or even a day if it's a major problem, before a ride, can pretty much ruin the ride unless you have spares available or it's something that is easily correctable.
    Yeah you're tired, dirty, and want a shower, a beer and to relax. But keep in mind the old Calvary adage, "The horse, the saddle, the man. There was a good reason for that order of maintenance. Rider er hard and put er away wet, and she may well not be ready the next time you need her!
    Just my 2 cents.
    Good Dirt
    T.W.O.
    Reputation: mimi1885's Avatar
    Quote Originally Posted by rlouder View Post
    Ha ha, that's on your list too, it's on top of mine
    Reputation: marpilli's Avatar
    I jokingly call it my "pre-flight check".
    Check and adjust pressure in tires.
    Check and adjust pressure in fork.
    Wipe down stanchions.
    Wipe down chain.
    Check brake functionality.
    Reset bike computer.
    Go!
    Fat-tired Roadie
    Nov 2007
    If it's been a week or so, top up the tires and fork pressure.
    Squeeze the brakes and rock the bike. Anything weird?
    Do I have my helmet, gloves, shoes, jersey, some power bars and gels, enough water, my tools?
    Let's roll...
    I also like to have a snack for when I finish, a towel, and a complete change of clothes. Sometimes I forget, or don't want to postpone my trip for shopping.
  1. Checklist for my first bike build!
    By dingleberries in forum Beginner's Corner
    Last Post: 03-08-2010, 05:06 PM
  2. Solo nite ride checklist. What's in your pack?
    By gixxerflier in forum Lights and Night Riding
    Last Post: 12-05-2009, 05:12 PM
  3. Used bike buying Checklist
    By Buboss33 in forum Beginner's Corner
    Last Post: 07-31-2009, 06:37 AM
  4. Commuting checklist....
    By coachjon in forum Commuting
    Last Post: 05-07-2008, 11:22 PM
  5. Checklist
    By Redmon in forum Nevada
    Last Post: 01-05-2008, 10:45 PM
