What upgrade would impove the bike?
Morning all, i've been riding a pretty cheap $500 Scott Reflex 40 for the past few years (Suntour XCR front, mix of alivio/acera drivetrain Deore LX rear, V-brakes, original wheels, Panaracer XCs, 30.2 lbs) and am thinking it may be time to upgrade something, to make it a little better and more nimble. I usually ride XC no major big drops, fast single track and some technical rocky bits. So, where would my money be best spent to improve my riding experience? I probably around $400 is all I have so a new bike is out of the question. drivetrain? shock? wheels? disc brakes? and any recommendations for parts etc?
Thanks in advance.
Professional Speed Bump
I would upgrade in this order:
- Tires
- Wheelset
- Brakes (Disc, if you have tabs)
- Fork
- the rest is depending on what kinds of improvement you would like to do (do you want: smoother shifting? lighter components? smoother pedaling? etc.)
I typically don't bother with brand new stuff unless they're on sale or closeout so if I had roughly $400 (give or take $50) to upgrade a stock bike I would buy slightly used parts (about 90% of intermediate to expert riders part out their bike not because they wore out or broken the parts, but because they upgrade...so finding good deals are easy):
- $30-50 pair of tires (lightweight XC)
- $80-120 better wheelset (disc compatible or disc only)
- $50-100 disc brakeset
- $80-150 mid-range fork (If you're sometimes lucky like me, you can find a relatively newer high-end fork for under $200)
In general, I agree with captainjoon. But replacing the RST thing on the front of my bike made a bigger difference than anything but tires, I think. Unless Suntours are better, you might start there.
Kind of a tie for me between a new fork and disc wheelset and disc brakes. At $400, you should probably choose just one of those. If you spend well, you'll be able to take those parts with you and they'll be very good components for many years. You could always go for a <$200 fork, but that's not going to be a HUGE upgrade over what you have. Likewise for buying both a wheelset and disc brake set. If you're happy with the fork, I'd focus on a lighter wheelset and disc brakes.
That being said, if you were to do both here's how I would go:
Fork - Marzocchi 33 TST2 ($200) - http://www.cambriabike.com/shopexd.a...sion+Fork+2009
Disc Compatible Wheelset: LX Hubs/WTB Rims ($129) - http://www.cambriabike.com/shopexd.a...+Disc+Wheelset
Disc Brakes: Avid BB7 Mech (x2) ($90) - http://www.jensonusa.com/store/produ...+Brake+09.aspx
Avid Levers ($19) - http://www.jensonusa.com/store/produ...Levers+08.aspx
Wheelset and Discs Only:
Disc Wheelset: WTB LaserDisc Lite ($299) - http://www.cambriabike.com/shopexd.a...+Sx24+Wheelset
It would be my preference to have lighter wheels over hydraulic brakes. The BB7's get the job done and don't require bleeding.
My 0.02 on the matter...I think I would either do everything but a new fork at first or maybe buy just a fork...but really +1 on TwoHeadsBrewing on the advice as well as the suggestions that he provided. I just bought a new crankset and upgrading to clipless...my crank was getting worn. I am waiting for my fork to blow before upgrading, the Rock Shock Dart 3 is holding good for now. I changed tires out soon after I bought it though.
Check out my blog! The WVPedaler...
Founding Member of THUMB MTB Club
2016 Trek Top Fuel
2015 Fuji Altamira Cross
Thanks for the advice, I was having a dig around this morning and was looking at wheels/brakes and kinda settled on the BB7s (under $100 for the set) and then wheels I was thinking about these for $130 http://bicyclewheelwarehouse.com/ind...d&productId=55 or +$20 to get the XT hub so that would bring me in at around $250 with some left over to a) keep the missus sweet b) to add to later for a better fork.
I upgraded my road bike wheels a few years ago and that made a massive difference, I really dont know how much improvement or what Id get from a better fork - smoother action? stiffer? better tracking?
Others will probably recommend a mid to low range new fork for that amount you have left but I would recommend a slightly used Reba or a Float.
I have these on one of my bikes. I think they work great.
Shimano LX dual control
Bleeding on Shimano hydros are super easy compared to other brake systems.
If you do the wheels and disc brakes upgrade now, you won't be limited to forks with cantilever posts when you shop for a fork later. That deal on BWW looks pretty awesome.
If you go mechanical discs, you don't need new levers. Although good levers do give better braking feel.
I would do wheels, tires, tubes, or a really nice fork. Both will save you weight. Losing a pound off my bike today and I am spending about bucks if you count me switching out my Panaracers for my Girlfriends lighter IRC Mythos tires I put on her bike. Also Maxxis Ultra Light Tubes.
Watch out if you upgrade to disc make sure your fork and frame are disc compatible.
a guy locally is selling this for $200 - sounds like a good deal?
"Manitou Minute Super w/ 20mm thru-axle and 140mm (5.5”) travel ($200)
-Fresh rebuild, new seals etc. Works exceptionally and is reasonably light."
and about 40mm to 60mm too much travel for his bike
his bike or my bike?
Sorry, your bike. His = You
rats! thought I'd found a winner.........
Look for something that is 80mm or 100mm of travel. Could even be a Rock Shox U-Turn fork.
This is a reasonably priced fork http://wheelworld.com/product/rocksh...l-air-6904.htm Just watch out for the steerer tube length. Measure your current one and compare to the one I linked.
hey thanks for the link and the advice - looks a decent price
The Recon I linked is only for disc brakes, so it kind of forces you to upgrade.
Have you thought about just selling the Scott and buying something that already has a better fork, discs and drivetrain?
Maybe something like this.
I would think that a ligher set of wheel, tires, going tubless, and possibly brakes would make a huge difference. The rotating weight is where the performance difference is most noticeable. I don't know what type of cassette you have, but going from a PG-950 to anything better would net you around 100-150g drop in rotating weight as well.
Tubes lost me 200 grams. Going from generic to Maxxis Ultra Light, Cost about 6 dollars a tube.
yeah, I'd thought about the new bike scenario and while I'd love to, I dont think I'd get much for the Scott and then its the extra for the new bike. If I upgrade, I know it'll cost more but I can do it over time and then hopefully have the parts to then upgrade the frame and be in really good shape.
you have $400 now, could probably sell your scott for $200 (modest guess, maybe you could get more, idk). save up $200 more and you could get a pretty nice hardtail if you looked around.
Upgrades like wheels and a good fork are a pretty good bet for transferring, but be careful about things like derailleurs, seat posts, collars... Anything that comes in multiple sizes, really.
EDIT: don't cut your steer tube if you can get away without doing so.
After going through something similar, I would suggest selling your current bike and finding a used bike with disc brakes. You will be getting an upgrade in everything if you find a 2-3yr old bike with mech disc brakes.
If you are in love with your current bike and hell bent on upgrading it, wheelset and disc brakes first, drivetrain second - fork last.
- You may not post replies
- You may not edit your posts
Forum Rules
