Results 1 to 5 of 5
    What rise on bar?
    My bike came with a flat bar, and it's alright but i always feel too leaned forward and after a while it starts to bother my back/neck. I want to get an '07 easton monkeybar riser but dont' know if i should get either low/med/high rise.
    pronounced may-duh
    Reputation: Maida7's Avatar
    Apr 2005
    The same effect can be achived with a stem that angles up more. The stem soltution will be lighter and stronger than a riser bar
    Reputation: oldskoolbiker's Avatar
    Jun 2005
    Sounds like you need a higher perhaps shorter stem. You didn't specify any specs about your current bike, but you could look for something along these lines.
    http://www.performancebike.com/shop/...tegory_ID=5230
    Quote Originally Posted by nelo
    I would like to hear this answer as well. I'm going to add an Easton EA70 Monkeybar Riser to my rig (98' Trek 8900). Does anyone have pics of bikes with the diff rises? Thanks.
    the rises really aren't a huge difference. I went from a low rise to a high rise and it was only a tiny difference in what I felt. If you're starting at a flat bar, I'd go with a medium rise. Low rise is practically flat and high rise might be a bit too much. hard to know unless you try it
