Results 1 to 9 of 9
    what is pedelkick? how rear wheel hop
    as title... What is pedelkick? Can anyone explain this please, and anyone know how to do rear wheel hop backward?
    Reputation: Pezerinno's Avatar
    Sep 2004
    Probably best to look up an explanation on a trials website but basically you release the back break/kick/hop simultaneously - this will no doubt sound bizarre if you haven't done it before. Before you try and pedalkick you need to know how to hop on your back wheel, to know how to hop on your back wheel you need to know how to unweight the rear end of your bike i.e bunnyhop (push down, back & up on your pedals etc).
    Most beginners when learning to pedal hop actually pedal hop backwards before they do on the spot as they push their weight too far back resulting in the bike re-centralising under you when you hop and therefore hopping backwards.
    I do sometimes use pedalkicking on very technical/rocky trails if I'm on my hardtail (I find it near impossible to do on my FS) but it may be a slightly more natural technique for me as I used to ride trials for a number of years. Also its generally not a great idea to do it with rear disc brakes as it puts a lot of stress on the frame - not designed to be pushing back on themselves (this is why most trials riders use rear HS33 rim brakes). You will probably find it quite frustrating when you start off learning but persevere and wear a helmet
    Reputation: natebyrom's Avatar
    go to www.mountainbike.com click on skill i saw some good stuff earlier
    Reputation: bidaci's Avatar
    Aug 2005
    another site.. with vids..
    www.trials-online.com
    Reputation: Kaba Klaus's Avatar
    And if you want to learn this kind of stuff fast: Go Ebay and buy a 20' Trial Bike.
    I tried first on my stock MTB, then changed stem and bars. Never got bejond hoping a couple of times. But destroyed a cassette, pinch flatted, untrued my wheel, ... Bought a trial bike and was hoping all over the drive way a day later. Good tool to learn the technique fast. Transporting that to a larger bike is easy enough.
    Reputation: Playdeep's Avatar
    Mar 2005
    Has anyone else had the same experience as the poster above ? I have spoken to many other experienced trials riders and many seem to think that the smaller bikes dont help. Not say ing the poster above is wrong.....just want to know before I rush out and buy one.
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    It's a pedal, not a peddle, pedel or whatever. Repeat after me, P-E-D-A-L.
    A pedal kick consists of getting up on the rear wheel and moving the pedals in a kick-ish motion while working the brake to achieve a forward hop.
    Ryan Leech can probably explain this better than me:
    http://youtube.com/watch?v=3ZQgD_anu2k
    I've ridden both stock(26'') and mod (20'') trials bikes and honestly to me they all pedal kick the same.
    Quote Originally Posted by Playdeep
    Let me clarify this: My first attempts were on an ordinary XC MTB. I could hop a bit with it - but never got to backwheel hops. Bought a 20" trials bike and was hoping on the backwheel the same afternoon.
    The magic for a beginner is the significantly shorter chain stay (20' trial versus 26' XC). Once you have the move dialed you can make it work on almost every MTB.
    I did not learn the move on a 26" trials bike. So I won't comment on if that would have been just as easy.
    I apologise for the incorrect use of the word 'stock'.
    "Lorem ipsum dolor sit amet, consectetuer adipiscing elit." - And I agree.
