Results 1 to 5 of 5
    Jan 2015
    What part is this?
    Hi, I just finished to convert my 3 speed crank into single speed using raceface narrow wide chainring.
    But in the process, when I pull off the crank using the crank puller, there is a part that fall off and I do not know what part is it and where its come from. Its somekind of a safety ring.
    Anyone know what part is it? Where is it should be installed?
    My crank is shimano fc-m571, hollowtech, octalink.
    Anyway, I did not install this part but my bike still working normal.
    Thank you
    Oct 2011
    I believe that is from your crank puller not the crank, my puller has a circlip that looks exactly like that.
    It is an external snap ring, meant to go on a shaft. Since you say your crank is Octalink that means you have a cartridge bearing bottom bracket.
    I would assume it belongs on the BB spindle to retain the cartridge bearing or spacers on the spindle.
    Quote Originally Posted by lolaralph View Post
    Or that :^) - it does look suspiciously clean and unused to be on a BB.
    Jan 2015
    aaahh..ic ic..thank you lolaralph..
    It could be.. my crank puller is new and I did not realize that part before.
    I'll try to find out where the part belong when im at home.
    THank you everyone
  1. Replies: 15
    Last Post: 01-24-2015, 03:53 PM
  2. Help me with this part
    By googas7070 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2014, 06:22 PM
  3. Replies: 10
    Last Post: 08-14-2013, 07:30 PM
  4. To part with or not to?
    By teleguy03 in forum Passion
    Last Post: 04-30-2013, 07:08 PM
  5. Replies: 1
    Last Post: 09-03-2011, 11:58 AM
