    What lube for swingarm pivots?
    What should you use to lube rear swingarm pivot points/bushings?
    Of course it depends on what type you have, but most require no lube.
    Mine are 2.5 years old with 11000 km, no significant wear yet, I do however use a bit of grease to try to seal the pivot joints so mud can't get in. Then every once in a while clean off and out the old grease and put some more on.
    Actually, I meant for squeaks.
    I would try a teflon chain lube. I was on the site of a pivot bearing supplier a while back and they say that lube is not rquired but oil or water is okay, as long as it is clean.
    But... I you really sure it is the pivot that is squiaking, I maintain six bikes and I have yet to have a pivot squeak (jamis and rockies)
