Results 1 to 6 of 6
    What do i need to upgrade to 9 speed?
    I have a 2003 hardrock with all alivio components on the drivetrain except for the rear deore derailleur, I want to upgrade to a 9 speed cassetteand the components to lx or xt. So I know I am going to change the shifters, both derailluers, the cassette and the chain. I want to know if I am also goign to have to change my crankset and my rear hub?
    And is there anything else I have to look into before I beging buying parts.
    Reputation: InvictaS1's Avatar
    Mar 2005
    no, you wont have to change your rear hub or crankset. most newer shimano drivetrain parts have rapid rise shifting, make sure all the parts you buy are compatible. if you buy rapid rise shifters you will need a rapid rise rear derailleur.
    Thanks, so the chainrings in my current crankset should work?
    Mar 2005
    yeah your current cranks and chainrings will work just fine.
    Ok thanks a lot for the info.
    Cheezy Rider
    Reputation: Rufudufus's Avatar
    Derailers aren't 8 or 9 speed specific, your front should be fine and you might not need to change your rear. Depends on if you go to rapid-rise or SRAM 1:1 shifters.
