Results 1 to 3 of 3
    Sep 2013
    What determines 9x or 10x?
    Just curious if someone can please explain to me what determines if a bike can have a 9x or 10x rear cassette? I have a GT Marathon with a 135mm rear end....it being 135mm, does that mean it can't accept a 10x? OR is it the rear wheel/hub that determines? I have Crossmax SLR's with a 9x currently installed.....will it accept a 10x cassette? Any explanation for this newbie would be appreciated! Thanks, Blake
    Jan 2009
    you should be able to put either on your bike.
    it depends on what type of derailleur, chain, cassette, and shifter you put on it. if you want 10 speed, get 10 speed-specific parts. if you want 9 speed, get 9 speed stuff. 9 speed stuff is cheaper. having one extra gear is not necessarily going to get you anywhere faster, but the newest generation of 10 speed chains and derailleurs seem to be more reliable. SRAM type II and Shimano Shadow Plus derailleurs have a built-in clutch that virtually eliminates "chain slap" and prevents dropping the chain. the new 10 speed chains shift superbly as well. if you don't have the budget for blingy XT stuff, the SLX line is excellent as well.
    10 speed cassette on 9 speed hub?
    Sep 2013
    Quote Originally Posted by mack_turtle View Post
    it depends on what type of derailleur, chain, cassette, and shifter you put on it. if you want 10 speed, get 10 speed-specific parts. if you want 9 speed, get 9 speed stuff. having one extra gear is not necessarily going to get you anywhere faster, but the newest generation of 10 speed chains and derailleurs seem to be more reliable. SRAM type II and Shimano Shadow Plus derailleurs have a built-in clutch that virtually eliminates "chain slap" and prevents dropping the chain. the new 10 speed chains shift superbly as well.
    Read that link....AWESOME.....make sense now! Thanks so much!
