Results 1 to 2 of 2
    Wet chain lube on inline skate bearings?
    I'm degreasing them now and was thinking of lubing with the wet chain lube I have... is that an ok idea?
    Reputation: Kaba Klaus's Avatar
    Doesn't do any harm but doesn't do any good either. The chain lube does not protect the bearings against moisture. Also chain lube will disappear fast. Unless you ant to reapply lube quite frequently you need to grease the bearings.
    "Lorem ipsum dolor sit amet, consectetuer adipiscing elit." - And I agree.
