Results 1 to 29 of 29
    Which way to lay bike down?
    Is there an accepted direction to lay a bike down on the ground?
    On my old bike I used to always lay it chain side up so as lessen the risk of damage to the derailleur... but now with disc brakes I'd worry about warping a rotor.
    So which way? Rotors down or derailleur down?
    Reputation: theMeat's Avatar
    Usually lean the back wheel on something so it stands up but if nothings around on the rotor side for sure.
    Round and round we go
    Reputation: Tim-H's Avatar
    rotor side but make sure it rests on the seatstay instead of the rotor.
    Fat-tired Roadie
    Nov 2007
    You're going to warp a rotor sooner or later if you ride hard. Don't sweat it.
    (And yeah - still the left side. Things don't stick out as much as the derailleur cage.)
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    Standing is the best way but if you have to lay it down make sure is laying on the non drive (left) side.
    Enthusiast
    Reputation: JonathanGennick's Avatar
    Left side down. Lay mine that way all the time. Nary a problem. Often the pedal holds the back end off the ground. The chainstay should be enough to protect the rotor, if you're at all careful.
    Tweaked hangers end up being the source of many shifting problems that I see. You're doing the right thing in not wanting to slam your derailleur into the dirt.
    Either way if I'm taking a downhill hairpin curve too fast and have to lay it down to avoid a tree or going over a cliff.
    Rotors are cheaper than derailleurs, so I lay it left side down, if at all. Given a choice, I prefer to lean it up against something instead, keeping it upright.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    If it cannot be stood up, non drive side.
    Reputation: square's Avatar
    Jun 2010
    why are you laying it down? is your kickstand broken?
    Nickel Havr
    Reputation: Eckstream1's Avatar
    Quote Originally Posted by square View Post
    Bwahahaha!!!!
    Thats funny right there!
    Quote Originally Posted by William Blake
    Great things are done when men and mountains meet. This is not done by jostling in the street .
    To me it doesn't really matter. I don't let it fall to the ground, so placing it gently down on the rear derailleur isn't a big deal for me. My rear der gets way more abuse from just riding. It's not like they are made of glass.
    Still New
    Reputation: gemini9's Avatar
    Mar 2011
    Get a Walmart bike. They have kickstands. Problem solved.
    I want to get a double kickstand, unsure of correct ter. I've seen them on carego bikes, big dummies, etc. Keeps the bike more upright which is useful for loading and unloading. More stable than just 1 leg.
    Banned
    my sister, whom I haven't seen in a long, long time was recently in the area and she saw my bike and asked why I have a rack for storage and wondered where the kickstand was
    Trail Ninja
    Reputation: Varaxis's Avatar
    I always lay my bike down on its left side, on the pedal with the crank arm at 12 o clock and on the end of the left grip. On clean dry ground, preferably dirt or grass not covered in snow or whatever.
    www.bigrobracing.co.uk
    Reputation: robdeanhove's Avatar
    Dec 2005
    Either is just fine, if you lay it down gently, the pedal generally takes most of the weight. I fall off on both sides and, in 15 years of mountain biking have only ever bent/broken two rear mechs or hangers both during big crashes, normally the mech is pretty well protected by cranks, pedals etc.
    This is particularly true for the newer shimano "shadow" rear mechs
    Try placing your bike gently in the ground on both sides and hopefully you'll see what I mean and you can put your mind at rest. But, yes, generally, leaving the bike leaning against something and on two wheels is best where possible
    Just don't throw it down, it'll be fine.
    What about upside down? Is that bad?
    B42
    B42 is offline
    Reputation: B42's Avatar
    Oct 2010
    Quote Originally Posted by konetiks View Post
    When I wrecked earlier today it was perfectly upside down on the handlebars and seat when it came to a rest. I'm assuming it wanted to be that way, so it should be fine.
    Fat-tired Roadie
    Nov 2007
    Upside down can have some undesired consequences, like scuffing on the top of the saddle or damage to the controls.
    I used to work on my bike this way all the time. Just pay attention to where it's contacting the ground. A friend of mine gave me back a road bike with some very annoying scratches on the tops of the shifters because she did this (probably a lot) in a cement-surfaced garage.
    Trail Ninja
    Quote Originally Posted by B42 View Post
    I think your bike is telling you something, considering that's the "emergency maintenance position".
    Well, I live in a apt. Complex. We keep our bikes in a giant closet. AKA the spare bedroom that we Swore would be the entertainment room but a year and a half later still remains entertainment-less. It's carpeted so I don't have worry about scratches.
    Reputation: CarolinaLL6's Avatar
    It just wanted its belly rubbed.
    I don't know if there is any truth to this, but a bike repair guy told me that storing bikes upside down over a period of time was not good because it could cause problems with the hydraulics in the brakes as well as problems with forks that have oil dampening systems.
    Five is right out
    Preferably the bike stands up against a wall or tree. But after riding for a couple of decades, I have never paid any attention to which side the bike lays down. Never damaged a rotor or a derailleur out of it either.
    Reputation: snowpunk's Avatar
    Iv'e heard of less expensive forks leaking but I don't see how it would affect hydro brakes.
    Trail Ninja
    Quote Originally Posted by Bungholio View Post
    The only way I see that being bad is if the seals went bad and developed a leak and all the fluid drained out over time. Storing it upside down isn't the cause, but it simply accelerates how bad the performance degrades due to the fluids leaking out of the bad seals. Riding a fork with no oil in it can cause some serious permanent damage to the fork.
    In some cases, storing it upside down for a while can help improve performance. Just under the seal where the fork lowers meets the stanchion tubes is a foam ring which helps keep the bushings, the inner part of the lowers which contact and slide on the stanchions, lubed. The bushings are slotted to let oil get above it to the foam ring, but sometimes the oil just splashing around doesn't keep the foam ring saturated. Turning the fork upside will do it though.
    As for hydraulic brakes, if you have air in it and turn the bike upside down, sometimes the air gets to the caliper and causes excess dead stroke (pull the lever and the brakes don't work or you don't feel pressure or weak pressure until late in the stroke) until the air's pumped back out into the levers. It doesn't dmg the calipers... just just causes you to have no brakes until the air gets pushed back into the little pocket in the lever where air can safely exist and not affect braking performance. Old DOT fluid tends to draw moisture from the air which turns into air when your brakes and brake fluid heats up and turns it into steam (AKA air). Usually performance is affected right away when your bike is turned over and doesn't need to be kept like that over a long period of time. Just a few pumps of the brake lever and maybe bouncing the bike will get it to work better again, until you can get it properly bled to offer a better long term solution to this particular issue.
    Varaxis,
    Thanks for the detailed explanation of what happens when a bike is stored upside down. It sounds like nothing much happens unless there is a pre-existing problem.
  1. Replies: 61
    Last Post: 10-25-2013, 08:35 PM
  2. Replies: 57
    Last Post: 07-09-2013, 02:22 PM
  3. mountain bike comfort, road bike speed,which bike?
    By traumamagnit in forum Bike and Frame discussion
    Last Post: 07-23-2011, 07:25 PM
  4. Replies: 5
    Last Post: 07-13-2005, 04:38 PM
