Results 1 to 10 of 10
    I'm Done
    Reputation: Durga's Avatar
    Feb 2005
    Washers Under Square-Taper Crank Bolts?
    The instructions for my old sq. taper cranks require washers underneath the crank bolts, or use of a bolt with built-in washers. My question is, are the bolts pictured below considered to be the type with the washers built-in? Just to be clear, on the pictured bolts, the flat portion (that would rest against the crankarm if no washer is used) is fused to the rest of the bolt. Thanks
    Mar 2011
    Yep - those are 'Built - In' washers and will work fine. Loads of Square taper cranks come with those
    I like turtles
    Reputation: TiGeo's Avatar
    Will work just fine.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    1/2 fast or 1/2 assed?
    Reputation: Koppuh Klyde's Avatar
    Ima go out on a limb and say just do yourself a favor and go splined.
    I'm a ******bag in real life so I dont have to be one on the interwebz.
    Quote Originally Posted by Koppuh Klyde View Post
    I will go out on a limb and say the 20year old XTR's I have are still going strong in Square Taper.
    Quote Originally Posted by AKamp View Post
    Let me borrow 'em.
    FWIW Ive been through a couple of square tapers w/ no luck. Old XTs circa 1989 and most recently stock Truvativ 5Ds that were replaced ASAP. Non drive side was coming loose causing rounding of the crankarm.
    If you didnt notice my ID Im on the heavy side @ ~250#.
    rider
    Jan 2005
    That would be the FC-M900. One of the best cranks ever made: cold forging!
    I have a couple of them in 180mm. I set them up with a Mountain Tamer adapter & 127mm BB and run them with 19-28-36T-ring guard. Sweet setup, the 19t front and 36t rear gives me a 15.3 gear inch granny on a 29er.
    Abandoned the 26" wheel in May '03
    Reputation: robselina's Avatar
    Durga,
    Others have answered your question, but here are a fiew little tidbits of advice on this job:
    1) Do NOT grease the square tapered faces of the BB spindle or cranks. Clean both well and install dry. Grease may allow a soft aluminum crank to slide too far onto the steel spindle, causing it to expand or crack.
    2) However, do grease the bolt threads and the 'washer' face of the crank bolts before installing them. This will allow you to ensure you reach correct torque for the crank arms.
    3) Make sure you torque the crank bolts to spec. If they come loose, you are liable to ruin the cranks since the mating faces warp easily when they are loose.
    Just my $0.02....
    rider
    Jan 2005
    As far as the don't grease the tapers go, I have bought a bunch of Shimano sealed SQ taper BB's over the years and a couple of them came out of the box with factory grease on the tapers. So I have tried them W & WO grease on the tapers & am not sure it matters much either way..
    I don't grease the crank bolt threads but will put a very small amount of grease on the crank bolt to washer interface.
    What I do know for sure is to not over tighten the crank bolts. Then I gently re-torque two or three times during the first ride and a number of times thereafter. After a while the crank bolts settle into a solid torque and only rarely need tightening thereafter.
