Results 1 to 10 of 10
    Reputation: TheRed's Avatar
    Jan 2011
    Used that green shimano grease on my BB & the excess has stained my frame!
    How do I get it off? It's like a really thin film.
    Has it permanently stained the carbon?
    Enthusiast
    Reputation: JonathanGennick's Avatar
    Hard to believe the stain is permanent. Have you tried to just wipe the grease off with a clean rag?
    I'm not sure which chemicals are safe on carbon. Perhaps a bit of rubbing alcohol? Dampen a rag w/it maybe?
    Maybe just try a bit of soap and water first. See what happens.
    Omg no!
    Jan 2011
    Quote Originally Posted by mmountainbiker View Post
    Omg no!
    You appear to be really upset about this? Are you OK? Do you need me to recommend a good counsellor?
    Give me your address and I'll send you some tissues.
    I don't have any personal experience with stains on carbon but try some car wax and a microfiber cloth. I have a feeling that would work (if it doesn't remove the car wax with rubbing alcohol so it doesn't coat over it making it harder to remove). Another thing to try could be WD40... and if all else fails try Mr. Clean eraser cleaning pads (basically a 2200+ grit wet sponge).
    Killing it with close inspection.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by TheRed View Post
    Carbon is black. A green grease stain would be nearly invisible.
    You can remove grease with a degreaser.
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    I have a feeling that some degreasers will dull the polished finish of carbon. I would try the least aggresive methods first. Use polymer safe degreaser if you go that route.
    Dec 1998
    Quote Originally Posted by FireLikeIYA View Post
    Sure, some, but far from all. Dawn dish soap is a degreaser. And you are cleaning the finish coating the carbon, not the carbon itself.
    mtbtires.com
    Dawn dish soap. Scientifically shown to be the most gentle soap. It's what they use to clean oiled seabirds. Really.
    Sent from my SAMSUNG-SGH-I777 using Tapatalk 2 Beta-5
    bacon (is my dog)
    http://www.sbtec.com
    Reputation: 3fast3furious's Avatar
    Dec 2010
    seriously, carbon is pretty tough. Even the resin is not easily broken down. Remember this is a space age material. In fact, its so tough to break down that there is no real way to recycle it. Most of it just gets landfilled. So most solvents won't really hurt the carbon at all. Now the paint is another story.
