Results 1 to 10 of 10
    GodSE Gozilla
    Jul 2013
    Caution;  Merge;  Workers Ahead! URGENT HELP!! Cannnondale Trail 5 or Trek 4300
    Hello,
    I am from India. I am around 6'1". I am getting a deal on Cannondale Trial 5 (Comes with Disc) 2011 and Trek 4300 (No Disc) 2011 almost around the same price! Can some one tell which is the best out of two?
    Also a word about sizing? Cannondale L or XL and Trek 21" or someother?
    Previously i am riding a bTwin RockRider 5.1 an entry level mtb so looking for an upgrade!
    They both come with 26" wheels!
    I would tend to think the L would fit you better than the XL. 21" is also very likely a bit big for you. (What's your inseam?) Most in your height range would be on a 19 or 20".
    GodSE Gozilla
    Jul 2013
    Quote Originally Posted by slapheadmofo View Post
    My inseam is 35.5"/90cm. Both have 26" wheels. The cannondale 2013 trail 5 geometry shows L corresponding to 18.7"
    TRAIL 5 - Trail - Hardtail - Mountain - Bikes - 2013
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Long torso probably puts you on an XL but you need to test them.
    The torso is not the inseam. Inseam equals leg. 35.5" inseam means a short torso and a L would be a stronger option. See if you can find a deal on a 29er.
    AZ
    AZ is offline
    Quote Originally Posted by eb1888 View Post
    35.5 inseam isn't all that long in a tall person, ask me how I know this. that's why I suggested test rides, you can't fit a bike over the internet no matter how good you think you are.
    GodSE Gozilla
    Jul 2013
    I have only two options to go with
    Cannondale Trail 5 2011 [Comes with DISC] = L Size [L Size implies 19"-21" here / 20" here / 20" in evans ]
    Trek 4300 [No Disc] = 21"
    Which will suit me? Which is more VFM? Both are same cost!
    GodSE Gozilla
    Jul 2013
    Cannondale Trail 5 Specs
    Frameset
    Front Travel
    100 millimeters
    Frame Material
    Aluminum
    Compare Aluminum Cross Country Bikes
    Frame Trail, double butted 6061 alloy, SAVE, 1-1/8 headtube
    Frame Size Range
    SM (15"-17")
    MD (17"-19")
    LG (19"-21")
    XL (21"-23")
    XXL (23"+)
    Fork RST Gila Pro TNL, 100mm, coil/elastomer, lockout, 1-1/8"
    Drivetrain
    Crankset
    Shimano M311, 42/32/22
    Rear Derailleur
    Shimano Alivio
    Front Derailleur
    Shimano M311
    Shifters Shimano Alivio
    Chain KMC Z-72, 8 speed
    Pedals FPD Platform w/ steel cage
    Components and Geometry
    Components
    Brakes Promax Orange Mech Disc, 160/160 mm
    Brake Levers Cannondale
    Handlebars Cannondale C4 riser 20 mm 6061 660mm
    Stem Cannondale C4 by Uno, 31.8
    Headset Tange ER2 Slim Stack
    Seat Post Cannondale C4, 31.6mm
    Seat Post Diameter 31.6 millimeters
    Saddle Cannondale Stage 2
    Grips S, M, L, X, J
    Wheels
    Rims Alex DC4.5, double wall, 32 hole
    Front Hub Formula DC20
    Rear Hub Formula DC22
    Spokes Stainless Black
    Front Tire Kenda Small Block 8 26x2.1", wire bead
    Rear Tire Kenda Small Block 8 26x2.1", wire bead
    Trek 4300 Specs
    Frame and Drivetrain Specifications
    Frameset
    Front Travel
    100 millimeters
    Frame Material
    Aluminum
    Frame Alpha Black Aluminum w/semi-integrated head tube, formed down tube w/integrated gusset, formed top tube, monostay seatstay, forged dropouts w/rack & fender mounts, replaceable derailleur hanger
    Frame Size Range
    XS (13"-15")
    SM (15"-17")
    MD (17"-19")
    LG (19"-21")
    XL (21"-23")
    XXL (23"+)
    Fork Spinner 300 w/coil spring, preload, hydraulic lockout
    Drivetrain
    Crankset
    Shimano Altus, 42/32/22
    Cassette
    SRAM PG-820 11-32, 8 speed
    Rear Derailleur
    Shimano Alivio
    Front Derailleur
    Shimano Altus
    Shifters Shimano EF51, 8 speed
    Pedals Wellgo alloy platform
    Components
    Brakes Tektro V-brakes w/Shimano EF51 levers
    Handlebars Bontrager SSR, 25.4mm, 25mm rise
    Stem Bontrager SSR, 25.4mm
    Headset 1-1/8" threadless, semi-integrated, semi-cartridge bearings
    Seat Post Bontrager SSR, 31.6mm, 20mm offset
    Saddle Bontrager Evoke 1
    Wheels
    Rims Bontrager Camino 36-hole rims
    Front Hub Formula alloy FM21 front hub
    Rear Hub Shimano alloy RM30 rear hub
    Wheels Formula alloy FM21 front hub, Shimano alloy RM30 rear hub; Bontrager Camino 36-hole rims
    Front Tire Bontrager LT3, 26x2.0"
    Rear Tire Bontrager LT3, 26x2.0"
    Bikes within a price range are very much alike ,if you can test ride them get the one that fits best.
    Reputation: CRchris1996's Avatar
    go with the cannondale for sizing both are really good brands
  1. 2011 trek 3500 vs 2007 trek 4300 vs 2008 trek 4300
    By TreyTRD in forum General Discussion
    Last Post: 03-23-2013, 09:56 AM
  2. Trek 4300 vs 4300 Disc?
    By slumpey in forum Trek
    Last Post: 12-02-2011, 09:04 AM
  3. Cannnondale Trail SL 4 comments, thoughts, ect...
    By clark3554 in forum Bike and Frame discussion
    Last Post: 06-21-2011, 09:38 PM
  4. Replies: 9
    Last Post: 04-17-2011, 08:57 AM
  5. Choice: '09 Trek 4500 or '04 Trek 4300 w/ upgrades
    By tardo in forum Bike and Frame discussion
    Last Post: 03-16-2011, 07:30 PM
