Results 1 to 7 of 7
    Feb 2006
    Upright position
    From what I read there is the belief that an upright position is not really appropriate for mountain biking. Why is that? I find it much more comfortable.
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    Upright
    Quote Originally Posted by Markleo
    It depends how upright. You need to be leaned over the front end a bit to put weight on the front wheel for steering and climbing. I have seen pics of proper fit with the back angled at 45 deg. I know I can get away with a more upright position with a shorter, higher stem and bars and still climb just about anything. I would suggest having the bars no higher than level with the saddle for XC riding. This is pretty upright but will still handle well.
    I got some bad ideas in my head.
    Bike to the Bone...
    Reputation: rzozaya1969's Avatar
    What's appropiate? If your back is completely perpendicular to the ground, then it's too far. But everyone has a 'best' position, but it vary from rider 2 rider, and also, aplication. If you're racing, maybe you want a more stretched position, but that would vary from what I would like.
    So, fit and positions are just guidelines, but not facts set in stone, IMHO.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Depends on what you are doing on the bike and what your priorities are.
    A long and low position allows you to lean further forward to maintain balance on steep climbs. A shorter cockpit makes it easier to move your balance back during hairy descents.
    There might also be differences in what sort of power your muscles can deliver in different positions.
    edit:
    I had to experiment a bit: I got a definite feeling that leaning forward for pedaling hard brought more muscles into play, not just the legs but up to my lower back.
    Reputation: RMBiker's Avatar
    Mar 2006
    How should your peddle stride be? Should it stop just short of full extension or less?
    Collector of Scars
    Feb 2006
    Quote Originally Posted by RMBiker
    Your leg should be slightly bent when you're at the bottom of the pedal stroke (just about 6 o'clock). You shoud NEVER be at full extension, as this is just a recipe for knee injuries. Personally, if i look down, at the bottom of the stroke, i should be able to see at least half my foot in front of my kneel, but it'll differ from person to person a little.
    Ross
    "I don't wanna die without any scars. So come on, let's do it before I lose my nerve" - Tyler Durden (Fight Club, Chuck Palahniuk)
    Full of holes
    Reputation: SwissBuster's Avatar
    Leg extension
    A good rule-of-thumb is to put your heel on the pedal and extend your leg fully. The saddle height should be such that your leg is fully extended when the pedal is as far away from your body as it can get (about 4 O'Clock position). You should be able to reach this position comfortably with both feet, though - not stretching to reach the full extension and not having to change body position to reach both sides. With your foot back on the pedal, this means your leg is not fully extended.
