Results 1 to 15 of 15
    Jun 2014
    Upgrade to entry bike
    I ride a Norco fluid 9.2. My first upgrade was a KS LEV dropper. Love it. Looking for some advice on a second upgrade. Most likely I will just ride it till something breaks but on the same hand I enjoy upgrading components and doing the work myself. Any idears?
    You could throw on a SLX Plus rear derailleur and SLX brakes. CRC has good pricing and Jenson matches.
    Jun 2014
    Quote Originally Posted by eb1888 View Post
    What are the benefits of a higher end derailleur? Obviously upgraded brakes stop better.
    The clutch mechanism on these new derailleurs will reduce or eliminate chain drop.
    And greatly reduce the noise of chain slap. You get a quieter ride. $65.
    Wheels are where you are going to feel the most difference.
    Jun 2014
    Do you need new chain? New crank? New cassette? If you switch out the derailleurs.
    Jun 2014
    Quote Originally Posted by rangeriderdave View Post
    Why is that?
    Quote Originally Posted by FlyFishermanPNW View Post
    No. You will have to undo the lower jockey wheel to get the derailleur off and the same with the new one if you prefer not to break the chain, unless you have a removable link already. KMC links work for 10sp.
    Jun 2014
    Sweet thank you. When I bought the bike my LBS said that's one of the first things he would replace.
    Why is that?
    For wheels you can get several benefits.
    Lighter weight makes them spin up quicker and easier. You climb over thing easier.
    You can also go wider inside dimension(30-35mm) for better sidewall support in cornering and less washout. You get more volume for more cushion and better climbing traction. You can run less air pressure.
    But you are spending $600+ with the low side cost for when you lace your own with Chinese carbon rims.
    Wheel building is easier than you think and fun. I use a Park TM-1 tension gauge.
    Jun 2014
    Sounds like something I would totally be interested in. Might have to start looking into that.
    Thank you
    Jun 2014
    Thank you!! Looks like 145 a piece?
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    That is just for the rim. no spokes, hubs, or building.
    Full wheelset from them is about $500 plus shipping. They make good wheels for the money though.
    I wouldn't spend money on drivetrain parts unless you brake or wear something out. You could buy a single narrow wide chainring and go with a 1x10 drivetrain which is about $50. It's not for everyone though.
    elixir brakes are great when they are working.
    My advice, go out and ride. You already have a solid bike.
    Jun 2014
    Quote Originally Posted by moefosho View Post
    Much appreciated!
  1. Replies: 50
    Last Post: 05-08-2014, 12:33 PM
  2. Entry level bike: This should be your first upgrade
    By Jem7sk in forum Beginner's Corner
    Last Post: 01-21-2014, 09:50 AM
  3. Question about future upgrade-ability for an entry level frame
    By Grease Monk3y in forum Bike and Frame discussion
    Last Post: 10-20-2013, 07:47 PM
  4. entry level Shock upgrade
    By ryencool in forum Shocks and Suspension
    Last Post: 11-28-2012, 02:49 PM
  5. Entry Level Fork Upgrade
    By cbzdel in forum 29er Bikes
    Last Post: 02-28-2011, 05:32 AM
