Results 1 to 9 of 9
    upgrade the drive terrain question
    Hey,
    I have the Wolf Ridge 6.7, and i would like to upgrade the drive terrain to X9/X7
    and have a few questions:
    this is my upgrade part list:
    SRAM X9 9 Speed Trigger Shifters
    SRAM X.9 9-Speed Long Cage Rear Derailleur
    SRAM X.7 GXP 3X9 Crankset (175mm)
    SRAM X.9 Front Derailleur (???????????)
    SRAM PG-970 9 Speed Cassette (11-34)
    Sram PC-971 Chain with Powerlink Gold
    here is my problem I don't know what Front Derailleur to buy
    SRAM X.9 Front Derailleur 31.8 or 34.9? and High or low and T/P or B/P?.
    can anyone help me to choose the right Front Derailleur?
    Reputation: Shakester's Avatar
    Jun 2012
    You can usually get an idea which clamp size you need by the diameter of your seatpost. If you have a 30.9 seat post, then more times than not, you'd need a 34.9 clamp size. You can try looking on the inside of your seat clamp since some have the diameter stamped on there.
    If you're derailleur cable is routed trough the bottom of your bike and under your bottom bracket tube, then you'd need a bottom pull. If your cable comes from where your seat clamp is and runs down, then you'd need a top pull.
    Quote Originally Posted by Shakester View Post
    Thank you, this helped.
    I don't see cable housing on your list.
    REI has a 25' roll of Jagwire for 24 and slick cables for 6 ea.
    A continuous run to the rear will make lower level components perform like higher quality parts.
    Drill out the stops.
    If you are buying all that, why not go 10 speed? Seems to be better deals on 10 speed components lately than 9.
    You should match the front derailleur type to the same as you are currently running. Use calipers to check your seat tube diameter.
    Quote Originally Posted by Slash5 View Post
    SRAM X.9 DRIVE TRAIN BUILD KIT + FS + no tax in most states 292$ - Slickdeals.net
    can't find some thing to beat this price........
    Reputation: peteer01's Avatar
    Apr 2005
    I still need some help with this. I understand that a Large frame AT3 (Nashbar 26") and 2013 Karakoram 2.0 29er would both be:
    Crankset: 175
    Front Derailleur Size: 31.8
    9 Speed Cassette Size: 11-34
    But I have no idea what either bike would be for Front Derailleur type. High T/P? High B/P? Low T/P? Low B/P? Can anyone help? I can't find any confirmation on that option, and I'm not used to those terms.
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    This site has the basics for front derailleur types.
    Front Derailleur 101
    A little more detail here:
    How to Buy a Bicycle Front Derailleur : CanadaBicycleParts Support
    Apr 2005
    Very helpful. The 26" bike I have that needs some new parts anyway currently have a low derailleur, with cables coming from the top, so I ordered the Low T/P, along with the 175mm crank, 31.8 tube size and 11-34 cassette. I also went ahead and ordered a bunch of the custom bike tools I'll need to get everything off and on properly, and I'm going to try to do this myself in the basement, and see how that goes. Should be fun!
  1. Costa Rica riders and terrain question
    By black1 in forum All Mountain
    Last Post: 06-25-2013, 02:39 PM
  2. Drive Train Upgrade Needed
    By Sinkhole in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-06-2012, 07:53 AM
  3. XT 2x10 Crankset Compatible with SRAM 2x10 Drive Terrain??
    By sbchisholm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-01-2011, 07:30 PM
  4. BB90 and upgrade drive train ?
    By kumarpr227 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-29-2011, 12:57 AM
  5. Drive train upgrade time!
    By darkz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-02-2011, 12:16 PM
