    Jan 2011
    UPDate : Suntour XCM stuck preload knob - partially unstuck
    Hi,
    I have a Suntour XCM V3 HLO 100mm travel fork on my 2011 trek 4500.
    The preload knob was stuck and when I tried loosening it with pliers, it got slightly warped. Fortunately, it was cosmetic. It moved only 2-3 mm.
    I tried again with an adjustable wrench and now, its moving more freely.
    It also looks like it's working (as I need to press harder on fork to make it move with extra preload. I have not tried sitting on bike).
    1)My doubt now is how many turns can I twist it either way ( - or + ).
    2) I have Finish line wet lube and also finishline stanchion lube.
    Should I put either of the above lubes around the preload adjuster to loosen it further?
    3) Do I need to do any maintenance for preload system ?
    My lockout knob is ok ( Possibly because I use it often).
    Thanks in advance and thanks to all who responded to my previous queries.
    Have a nice one.
    Class Clown
    Reputation: dundundata's Avatar
    I would advise removing the topcap and getting inside the fork rather than try and force things. You need a special tool though I think although could be a work around. In anycase I'm interested since I have a new XCT. Haven't even messed with preload now.
    Reputation: hankscorpio's Avatar
    Jun 2012
    Mine did the same thing. My new Manitou Tower should be here this week at which point I plan on going "office space" on my suntour
    Jan 2011
    Hi, I turned it towards less preload. I may have moved it towards minimum setting. It seems to be stuck again. The travel is 100mm. I tied a ziptie and when I sat on cycle and pressed brake too, displacement (sag) is approximately 32mm. Looks like this setting is ok. I weigh approx 215 pounds.
  1. Broke my preload adjustment knob....
    By IanIanBoBian in forum Shocks and Suspension
    Last Post: 07-31-2016, 04:47 PM
  2. Replies: 1
    Last Post: 04-23-2013, 01:39 PM
  3. suntour preload knob replacement
    By cams-76 in forum Beginner's Corner
    Last Post: 07-19-2012, 09:12 PM
  4. What the F@(k Fox f120 RL Rebound Knob Stuck
    By chtorres2 in forum Shocks and Suspension
    Last Post: 05-08-2012, 05:38 AM
  5. ProPedal knob on RP23 is stuck.
    By singletrkmind in forum Shocks and Suspension
    Last Post: 10-19-2011, 11:38 AM
