Results 1 to 12 of 12
    Apr 2013
    The two rings in the front?
    I only use the small inside front ring, and the big outside ring always hits stuff should/can I get rid of it?
    Reputation: MSU Alum's Avatar
    Nah, makes a good bash guard and you'll use it, eventually.
    Yeah, as you get stronger you will find yourself using the small ring less and less. And even now, when going down rooty and rocky downhills, use the big ring. If you crash, the big ring will be covered by the chain, protecting you from the sharp teeth.
    That said, it seems a lot of guys are going for 1x10 nowdays. What size are your rings?
    Reputation: JoePAz's Avatar
    May 2012
    I have 3 front rings and I used all of them. Middle ring for flat riding or gentle up/downs. Little ring for longer sustained climbs. Big ring for pavement or fast descents.
    Joe
    '18 Specialized Epic 29", Vassago Verhauen SS 29", '13 Santa Cruz Solo 27.5", XC, AM, blah blah blah.. I just ride.
    Apr 2013
    Quote Originally Posted by DennisF View Post
    Is 2x10 a size? I have a Stache 7.
    Ok, what I was referring to was the number of teeth. You have 38/24. 24 is pretty small -- I don't think that would make a good 1x10 setup. Unless you are riding uphill all the time (I know it SEEMS that way ), you will be using the big ring.
    Trek Bicycle
    BTW, in case you don't know about cross-chaining -- you want to keep the chain line as straight as possible. Look at the sideways angle of the chain as it comes off the ring in various gear combinations. The less angle the better -- it will wear less and pedal slightly easier.
    So while small in the front and a smaller cog in the back might be a high enough gear for level or going downhill, it is better to use the big ring and a medium cog.
    You don't have to be anal about avoiding cross-chaining. That's the great thing about a 2x system -- no gear combination is horrible. There is nothing wrong with doing what you have to do to get the ratio you want as fast as possible.
    Nice bike BTW. I love hardtail Treks with their G2 geometry. I have a Superfly AL Elite I converted to 2x. I see yours has a "Turbine" ring. From the photo it looks like a RaceFace Turbine ring. That's what I put on mine. They shift VERY well. You have a good setup IMO.
    BTW, when it comes time to replace your rings (and I understand that the RaceFace's last a very long time ) you could replace them with a RaceFace 36/24 set. That's what I have. It would give you a little extra clearance and is $10 cheaper than the 38/24.
    Apr 2013
    Great info thanks man. I'll try riding with the big ring more. The Superfly AL was on my short list.
    May 2012
    Quote Originally Posted by ptex View Post
    There no requirement to ride the big ring, but it is there for a reason. Most people find it useful to have additional ratios. Personally I am not a fan of 1x9 setups as I like bike that has enough gear range for any conditions. I have only one bike I want it to work on steep climbs as well as fast smooth descents.
    Joe
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    Remove the big ring and replace it with a bash guard.
    Apr 2013
    So I used just the big ring last night and the chain bounced off, could it be related to the big ring? Also go a flat seemed to be leaking from around the stem is that possible?
    Reputation: KAriadne's Avatar
    Was the chain coming off to the outside? You may need to adjust the the H limit screw. If you weren't using the big ring before, you wouldn't have noticed that problem. It controls how far out the front deraillieur goes.
    The Park Tool article on it is thorough: Park Tool Co. ParkTool Blog Front Derailleur Adjustments
    Yes, it is possible. Confirm the exact nature of the leak with a spray bottle and soapy water, or dunk the rim in a bathtub or pool.
    Is it leaking where the stem comes out of the rim? Have you converted to tubeless?
  1. Changing Front Rings...Is it worth it?
    By allthatflash in forum All Mountain
    Last Post: 05-20-2013, 04:42 PM
  2. Cleaning the front chain rings?
    By Phillbo in forum Arizona
    Last Post: 03-12-2012, 03:30 PM
  3. when do u know when ur front rings are toast?
    By SamL3227 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-27-2012, 02:22 PM
  4. SRAM 22/36 front rings?
    By RLSV211 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-15-2011, 06:36 AM
  5. Want to change ratio of front XX rings (2 X 10)
    By kgbuds in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-21-2011, 06:27 AM
