Results 1 to 7 of 7
Thread: Two questions.
    Aug 2013
    Two questions.
    1. Where should your foot be placed on a flat pedal? I place the middle of my foot on the pedal. I see others place there toes on?
    2. How far to look ahead?
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    I normally would ride with the balls of my feet in the middle of the pedal. That way I can adjust, drop my heels easily and keep all of my weight on them. It shouldn't be the middle of your foot or the toe.
    Look ahead as far as you need to, to be able to see the terrain before you get to it and have some time to adjust your line, brake, lean, hop, etc.
    Aug 2013
    When I look ahead I can't see things close to me even in my peripheral vision.
    Does the pedal have to be aligned with the balls of your feet?
    I ride bikes
    Apr 2013
    If you feel more comfortable at first with the pedal in the center you can go with that and slowly each ride focus on moving it slightly forward. You definitely dont want it under your toes, but a bit closer to the middle is ok.
    Your peripheral vision doesn't have to see all of the details because you have been looking ahead and know what is coming.
    Aug 2013
    But when something I saw when I looked ahead comes near me don't I need to see it with my peripheral vision?
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    When you're walking, do you look at your feet? Forward vision will become easier with experience.
    On the foot placement, for the most part the ball is the most effficient place for the foot to be for pedaling. It will also allow your saddle to be a little bit higher (most new riders run theirs too low). If you look at a cycling shoe, the placement of the cleat is adjustable, but slightly so and just around the ball. If you're a jumper with a bad ankle this can be a problem. I've actually started using flats mostly because I like to jump everything I can find and so on the way down I run my foot on the pedal much closer to the arch.
    Aug 2013
    Okay Thank you
  1. BCT questions
    By Douger-1 in forum Arizona
    Last Post: 03-04-2013, 04:11 PM
  2. 960 XTR 2x9 questions
    By JMac47 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-14-2012, 09:32 AM
  3. 1x9 questions
    By spokes01 in forum 29er Bikes
    Last Post: 06-21-2011, 10:47 AM
  4. Need some help, have a few questions
    By stburr91 in forum Beginner's Corner
    Last Post: 04-12-2011, 10:27 AM
  5. Replies: 12
    Last Post: 03-11-2011, 05:35 PM
