    Jul 2013
    Trek Stache 8 or Marin Rocky Ridge
    Tough time deciding between the two.
    2013 Stache 8 - Bike Archive - Trek Bicycle#
    Rocky Ridge 7.6 | Marin Bikes
    29 vs 27.5. Trek vs Marin. Will be used for trail riding, mostly flat.
    Fat-tired Roadie
    Nov 2007
    They're both going to have really high front ends. They strike me as bikes with a more AM attitude.
    Really, it's try both (or as many as you can) and buy your favorite. I'd suggest trying some hardtails with 100 mm of travel while you're at it. Make sure you really want long travel and a slack head angle.
    What are you riding now?
    Reputation: Kiwiplague's Avatar
    The Rocky Ridge has always been designed to be at the more hardcore end of the XC/trail spectrum, so it is looking to be be a little bit overkill for the style of riding that you say you are doing.
    I'd also recommend going with a 100mm fork based hardtail (either 26 or 29er), you will find it more suited to you I think.
    Also, slightly off topic, but noticed bit of a typo in the specs for the Rocky -
    Brakes Front: Avid Elixir 7 Trail Hydraulic Disc, 7 Rotor
    Brakes Rear: Avid Elixir 7 Trail Hydraulic Disc, 6 Rotor
    Brake Levers: Shimano Hydraulic
    Not too sure shimano mineral oil levers are going to work terribly well with Elixir DOT based brakes!
    I don't crash, I just have slightly uncontrolled dismounts!
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    If you are going to be riding trails, mostly flat then neither of those would be the perfect bike for that situation.
  1. Diamondback Mason (base) vs Marin Rocky Ridge 7.4?
    By c5marine in forum 29er Bikes
    Last Post: 08-20-2013, 03:23 AM
  2. 2014 Marin Rocky Ridge - Slack 27.5!
    By c5marine in forum 27.5
    Last Post: 07-27-2013, 08:04 PM
  3. 2005 Marin Rocky Ridge - Worth?
    By mc4nam in forum Marin
    Last Post: 08-10-2011, 10:29 PM
  4. Replies: 3
    Last Post: 07-09-2011, 10:44 AM
  5. Replies: 11
    Last Post: 04-18-2011, 05:46 AM
