Results 1 to 6 of 6
    Jun 2014
    Total noobie here!
    To start off, y'all have a lot of excellent advice and many great tools for learning how I should be riding and trail etiquette. My coworker has recently gotten a specialized Hardrock 29 disk (21" frame), which is what got me interested in losing weight and being outside, especially after he let me take it on a trail.
    There are many different questions that I have, wheel size, frame size, brakes, seat, gear sets, helmets, shoes, pedals.. the list will never end..
    I have been 2 a couple different shops, in the Dallas, TX area.
    Here is what I have come up with:
    • As a 5'9 233 LBS male with a longer torso than legs, I should be getting a 16-17" frame.
    • Disk brakes are the way to go. Hydraulics aren't necessary at this stage.
    • Seats, gear sets, helmets, shoes, pedals.. don't matter right now.
    • Wheel size is where I get lost on.
      • 29" wheel, have great roll over, a greater inertia, slower acceleration and larger turning radius.
      • 27.5 wheel, have decent roll over, a decent inertia, decent acceleration, decent turning radius. Middle ground of the 3 sizes.
      • 26" wheel, has the "worst" roll over, "worst" inertia, best acceleration, and best turning radius.
    I've haven't decided which wheel size yet, but Its between the 27.5" & 29" wheel size. Giant Talon 4 27.5" ($575) or the Specialized Hardrock 29 disk ($590).
    TLDR: Which of the two bikes is "better", or is there something else I should be looking at?
    Oct 2013
    Buying a good used bike is a better way to get much higher quality than paying full price for a bike with low quality components. A $600 bike is going to have a front shock that will be not stand up long to riding on anything other than the street. There are a lot of bikes that get ridden a few times and collect dust and are eventually sold at good prices. Check out Craig's list in you area, you may find a bargain.
    Fat-tired Roadie
    Nov 2007
    Re: Total noobie here!
    17" is probably about the right frame. I'm just a touch shorter than you and ride that size myself. Go ahead and try a 15" and a 19" though, so you know what that feels like.
    People emphasize wheel size way too much. For me, 29" wheels are a little smoother, with no particular downside. But I haven't stopped liking my 26"-wheeled bike.
    All $600 retail bikes are going to be pretty comparable. I don't think they do very well on longevity or performance, so if you have time to do a little more legwork, I encourage you to look for a used bike instead. Via a shop can let you keep some of the value-added aspects of buying retail while getting a bit more bike for your money.
    Jan 2013
    Quote Originally Posted by Coverdog View Post
    Couldn't agree more. Buying a used bike is the way to go for a beginner on a budget. Also don't forget to check out eBay OP as a lot of good deals get listed there recently.
    Trail riding can be rough with rocks and roots you don't have on dirt roads or bike paths. The control from your fork when you have front suspension becomes the most important component in fun riding.
    Most bikes you find in your range have a simplistic fork designed to work well on bike paths but no way are they ok for trails. XCM, XCR, and XCT coil spring Suntours fall into this category.
    I've probably mentioned this new bike on ebay 20-30 times this season.
    It is in the $600 range. It has decent Shimano Alivio/Deore drive components. But the fork is a good mid-range component. A Suntour Raidon air fork(necessary at your weight) with tapered steerer, 4.3 lb weight vs 6.2 for an 'X' fork and a maintenance free sealed oil damper instead of a greased spring.
    Search 2013 Marin Bobcat 29 on ebay. I am not connected with Crosslake or the listing in any way.
    They have had a lot of 2013 bikes available this year. Lucky.
    You are likely a 17.
    Reputation: peteer01's Avatar
    Apr 2005
    Quote Originally Posted by Speculati0n View Post
    Assuming your friend is willing to help you, I would either buy used, or buy from a company like Airborne. At the amount you're willing to spend, you're going to get a lot more bang for your buck that way.
    Here's a link to the Airborne Guardian:
    Airborne Bicycles. Guardian 2.0
    Ride a 29er, 27.5 and 26" before you decide what size wheels you want, if you can. If that's honestly not an option, you're really not going to go "wrong" with any of them, as long as you get the right size frame for your body.
    I would recommend considering spending a little bit more if you can. I spent about $600 on my XC hardtail (and it was on a huge sale when I bought it), and the fork simply wasn't up to what I needed from a fork. If you buy a decent bike to start, the components and total cost are a lot cheaper than if you buy a less expensive bike, but find yourself upgrading a fork or brakes in the first year. (If you were willing to look at Airborne's Seeker, for example, that comes with a much more reasonable fork than an XC28 or similar entry level fork.)
  1. Noobie
    By dcw1sfu in forum 29er Bikes
    Last Post: 08-10-2013, 10:02 PM
  2. Noobie just joined
    By trinibajan in forum General Discussion
    Last Post: 07-10-2013, 02:34 AM
  3. Noobie commuter.
    By Mirrorsaw in forum Beginner's Corner
    Last Post: 07-07-2013, 08:30 PM
  4. Noobie needs help.
    By RoadBiker12 in forum Beginner's Corner
    Last Post: 03-30-2013, 12:18 PM
  5. noobie
    By francois1 in forum test forum
    Last Post: 08-09-2011, 07:40 AM
