    Feb 2014
    Topgun vs. Zoom fork
    Hi Everyone,
    Decided to give a generic electric bike a new home today. When I say generic, I mean this e-bike is extremely generic... not much info online. The brand is Progear and the model is Metro E80... good luck if you find any info on it.
    Anyway, I want to change the front fork because what I have on there now is on the low end of the quality scales. The bike currently has a "Topgun" 26" suspension fork. I think it might be 63mm travel as I measured the axle to crown and it's like 430mm or thereabouts. Currently doesn't bottom out but it's "soft" for my liking and lacks adjustments.
    Now being the e-bike fanatic I am, I have another e-bike, an expensive $2500 eZee Sprint which uses a ZOOM CH-141 fork. Also 430mm axle to crown and has adjustment for both "legs". Comparing this fork with my Suntour XCT on a mountain bike, it's pretty low end... doesn't bottom out but pogo stick like even compared to a low grade suntour.
    Because my fantastic generic e-bike uses old technology... it has a 1" threaded headset. Shame not 1 1/8", but the old 1" so it's made it really hard to find anything decent.
    Anyway, the store that sold my Sprint has the 1" threaded CH-141 Zoom fork in stock with the same steerer tube length as the Topgun.
    Would there be any improvement over the Top Gun fork? Or should I just not bother and leave it as is?
    Bike will be used around the city environment on hard pavement - no offroading at all.
    Thanks.
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    I would say both of those forks are garbage and you would be better off on a rigid fork.
    Feb 2014
    Quote Originally Posted by moefosho View Post
    I was looking into that just now. I just saw a Kona P2 from bikeman with a 1" threadless steerer and 410mm axle to crown.
    Yay or nay?
    I'll need a new threadless 1" headset, hard to find 1" spacers and also a hard to find 1" adjustable stem...
    I have a surly 1x1 rigid on my Giant and I love it. Light and nimble, total control over the front end as it's firm and responsive.
    Feb 2014
    Hi everyone,
    Did some more research and managed to track down RST Gila T fork with 80mm travel and 1" threaded steerer 200mm in length for $80!
    Very cheap in my opinion.
    Axle to crown with RST Gila is 460mm. Stock top gun fork A-C is 435mm or thereabouts. If I put the RST fork with a 25mm longer axle to crown, does that mean my steering is more responsive and sporty?
    Any other issues I should be aware of with a 25mm longer axle to crown? Will my frame crack or anything? It's a step through bike...
    Thanks.
  1. Replies: 13
    Last Post: 04-09-2014, 02:29 PM
  2. How do you use PVC pipe to make walmart zoom forks rigid?
    By Blackdout in forum Shocks and Suspension
    Last Post: 04-02-2014, 05:29 PM
  3. Topgun forks?
    By Falkon45 in forum Shocks and Suspension
    Last Post: 01-26-2013, 05:18 AM
  4. Lose anything on the Zoom trail up at WP?
    By HuckleberrySS in forum Colorado - Front Range
    Last Post: 08-06-2011, 08:02 AM
