Results 1 to 6 of 6
    Tools needed for a FRAME REPLACEMENT
    Hi, I'm wondering what tools I would need to replace the frame on a 2005 S Enduro. I might be getting a Medium frame to replace my Small one.
    Reputation: dir-T's Avatar
    If you're going to replace everything yourself you will need...
    - A headset press (a real one or some improvised version)
    - A h-set race removal tool (or be real careful with a chisel and hammer)
    - Bottom bracket removal/installation tool
    - A set of allen wrenches
    - Cable housing cutters would also be helpful
    - A hacksaw (if you need to cut down the steerer tube on your fork)
    You could also do just about everything with a set of allen wrenches and have a shop swap the bottom bracket and headset for you. That may be cheaper and easier than buying the tools unless you plan to replace a lot of headsets in the future.
    Reputation: antonio's Avatar
    Jan 2005
    Quote Originally Posted by dir-T
    Agree with this. You should have a pair of cable/housing cutters in the tool box since you should be replacing that stuff once a season or so. But, besides that, you won't often find yourself replacing headsets or bottom brackets. (Then again, I have removed and regreased the bb on my bike twice in the last year to alleviate squeak sounds).
    Ant
    Quote Originally Posted by antonio
    (Then again, I have removed and regreased the bb on my bike twice in the last year to alleviate squeak sounds).Ant
    Yeah, a bb tool can be handy in the long run. I've replaced or relubed quite a few bbs over the years. That can definately save you time and money compared to taking it to a shop whenever your bb is creaking or worn out.
    I forgot to mention, you may also need a crank puller unless your cranks are the self-extracting type.
    Thank you for all the info. Would you recommend Park Tool? the company shows up in google in almost every search for the tools you mentioned. Thanks again.
    Jan 2005
    Park makes the best tools, which is why they're a little more expensive.
    If you're going to buy bottom bracket tools, keep in mind that different types of bottom brackets require different tools, so purchase the one specific to your crankset.
    Last note: if you're swapping parts to a whole different model frame, you may possibly need a new bottom bracket (they come in two widths) and a new front derailleur to fit the seat tube of your new frame (as well as a new seatpost).
    Ant.
