Results 1 to 11 of 11
    Toe, middle, or ball??
    So should i be peddling with my toe, middle or ball of my foot? i noticed that i pedal more with my toe going uphill and when im on flat surface i use the middle of my foot or the toe. What would be less strenuous?
    I find using the ball of my feet to be the least strenuous.
    Reputation: 4slomo's Avatar
    Zinn recommends the ball of the foot directly over the pedal spindle, or up to 2 cm in front of the spindle.
    Reputation: cycle.tim's Avatar
    On a road bike you set your cleats on your shoes to match up with the balls of your toes and that puts you over the spindle. If you are riding regular pedals I still think you should be using the ball of your toes but if get tired switch to your heals and you will use your hamstrings more than your thighs. Using your heals though is only for when you can sit down and pedal without having to worry about a lot of techi stuff.
    I only responded to this lame thread because I wanted to increase my posts count.
    Reputation: spazzy's Avatar
    i tend to slide my feet forward alittle so my foot is centered on the pedal if im doing a rough section so i have more leeway if i get bounced around
    The ball of your foot. It brings your calf muscles into play and uses your ankle for some "suspension".
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    It's pedaling, peddling is quite a different thing.
    don't thread on me
    Reputation: Roswell52's Avatar
    Quote Originally Posted by snaky69
    Too funny Snaky..or is it two funny!
    12gaugehug. Go with clipless pedals. Problem solved.
    Oh!, and check out my signature for a little clarification on peddling....
    sign here ________________________
    what would any of you recommend for a clipless pedal?
    AKA Dr.Nob
    Reputation: gumbymark's Avatar
    Quote Originally Posted by a12gaugehug
    Doing a search
    Not that all teenagers are evil mind, just most of them.
    Shimano PD-M520. My LBS sells them for $50. They're cheaper than other pedals and you can adjust the tension of the spring while you are learning to ride clipless. To top it all off, your shop will adjust the cleat position for the best fit for your feet.
