Results 1 to 9 of 9
    Tire Width Question
    I had a pair of 2.3 width tires on my mountain bike. The front tire was damaged after a crash, a tear on the side of tire. I was wondering if it'll make a huge handling difference if I put a different width tire on the front when I replace it, like a 2.2? Just wondering since I've not had any luck so far finding a 2.3 tire, but still looking.
    Thanks for your time.
    jalopy jockey
    Tire selection is such an intimate question. What I love others hate. Most people in my parts run 2.1s or smaller.
    I Have Cookies
    Reputation: ae111black's Avatar
    Dec 2008
    2.35" will work ok, what brand did you have on? Because not al 2.3 tires are created equal.....
    The most important thing is what God thinks about it. He will have the final say. Joshua Stinebrink
    ____
    Kimo
    Fat-tired Roadie
    Nov 2007
    The width difference won't be hugely important, but a different rubber compound or tread pattern could make a lot of difference.
    Quote Originally Posted by ae111black
    Continental Vertical Pro
    Quote Originally Posted by AndrwSwitch
    Ah, okay I'll have to check into that.
    I ran into the same thing.
    Kid on the bike floor at w/m tried to tell me "all tires in these numbers are the same." We all know that's total BS!
    I wanted to try a kevlar as they're supposed to be tougher. With my wt in riding setup at 250# I feel a real need for a better quality tire for rocks and general riding just hitting anything can bust one quick.
    Ended up getting a rolled up tire that when opened, turned out to be a 1.95, replaced a 2.3 unmarked. Expect that's going backwards to my needs. I do have another old woman's bike that needs tires so this will likely end up on it before long. Once I find the one I need.
    Am totally disappointed in the LBS. Fancy bldg, been there 15-20yrs. First time in right after opening it was stuffed with fancy new bikes. Yesterday I spilled the balls out of the rear bearing & couldn't find the last one. So I went down there. He does have a nice selection of older collectors items, maybe 30 bikes in all, or more. Not a new one in sight. less than ten new tires on the rack, very little other stock. Total dope head type guy that's partner in the place. Even told me that bearing was fine when it was obviously missing a ball. Since he had them, I got one and put it in. Fits just like a bearing is supposed to. I've been around mechanic's over 60yrs so I KNOW what bearings look like.
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    Quote Originally Posted by GeorgeLD
    Like any other business there are good and bad bike shops. Hit them where it hurts at their wallets so hopefully another owner will move in and run it correctly.
    There is not much choice between rotten apples.
    Rod
    Rod is offline
    Oct 2007
    This is a very good post. Tread pattern and compound makes all of the difference. See what others use in your area and see what you like.
