Results 1 to 6 of 6
Thread: Tire Pressure?
    Reputation: nstp0316's Avatar
    Tire Pressure?
    Hey everyone,
    I have a 2013 Specialized Carve Comp 29er and my GF has a Specialized Myka. I was wondering what everyone recommends for tire pressure in these two bikes? Thanks in advanced..
    Reputation: 65mph12's Avatar
    You may have better luck using search. This is the type of question people tend to ignore.
    ___________________________
    Jeff
    Aug 2013
    I do not have a very good answer to this, but tire pressure depends on at least the following factors: The tire volume (fat tires can run lower pressure), your weight, the terrain and probably your driving style. I do not have a formula, but a good tire pressure is probably lower than what you'd expect.
    Studies seem to show that a lower tire pressure does not impact rolling resistance as much as you'd think. Some people recommend going lower until you experience pinch punctures from hitting rocks/curbs, and then going a bit above that.
    Jeff recommended using the search function, there are many threads (and opinions!) on this topic
    ****** to the dirt
    Reputation: deke505's Avatar
    It is up to you to try and find the right pressure for your riding type. Just experiment. If you get a pinched flat it means the pressure was to low.
    Quote Originally Posted by Optimus View Post
    There's some strange folk out there 'bouts. They have no sense of humor.
    My Blog
    Fat-tired Roadie
    Nov 2007
    I don't know. Figure it out. Start with the minimum pressure on the tire sidewall, and experiment from there. Try about 5 psi at a time.
    Reputation: MSU Alum's Avatar
    From Wheels and Tires: Sticky: Tire pressure for all around XC riding? Generally, the lowest pressure you can get away with without pinch flatting is a good target. Depending on the tire and the rim width, low pressures can lead to a feeling of the tire "folding under" on hard turns. Experiment around and see what feels best.
  1. Tire pressure help?
    By Cheedah in forum Wheels and Tires
    Last Post: 05-24-2013, 01:02 PM
  2. Tire pressure help
    By CabinDweller in forum Wheels and Tires
    Last Post: 05-09-2012, 04:17 AM
  3. Tire pressure
    By gsheffer in forum Downhill - Freeride
    Last Post: 04-01-2012, 09:50 AM
  4. Tire Pressure
    By AllisonWunderland in forum Beginner's Corner
    Last Post: 06-20-2011, 05:49 AM
  5. Tire Pressure??
    By Brownbear15 in forum Wheels and Tires
    Last Post: 04-26-2011, 02:51 PM
