Results 1 to 6 of 6
    Tire change and back brakes arent working (disc)
    i have a 2012 trek mamba, and i out new tires on it today, the only problem is now the back disc brake doesnt work the first half of the pull and when it kicks in the disc gets really hot
    i cant figure out why, i have had it off before but this is my first disc brake bike lol i took it off a few times and out it back on but it didnt help anything
    Reputation: Trauma05's Avatar
    May 2012
    Are both pads still on the caliper?
    yeah they are, actually i took it back off and accidentally hit the brake lever and the pads are closed now so i have to figure out how to open them back up haha
    check to make sure your rear wheel is aligned correctly in the drop outs. You should hold the rear brake when tightening your QR so it holds the wheel in place.
    Thanks for the tip
    How do you open the caliper back up? ( both pads are basically touching each other)
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Quote Originally Posted by crestfallinman View Post
    Thanks for the tip
    -remove wheel and pads
    -take a plastic tire lever, put it in and pry to one side to push piston back into caliper
    -repeat on other side
    -repeat again on first side (b/c pushing in one piston pushes out the other a little)
    -etc. til pistons are retracted
