Results 1 to 5 of 5
    Time to upgrade.. $1500 AM
    I've had a fuji thrill LT 1.0 for the last few years. It's been a great first "real" MTB, but just never felt quite right underneath me, and after getting into riding a bit more I want to upgrade to a better setup. I'm 6'3" and about 190lbs. I'm trying to keep my budget to $1500 (used). I have a couple bikes in mind, but was hoping for some more opinions on what bikes to look for.. Mainly looking for full suspension in 150-160mm travel.
    Here's one I found, a 2013 diamondback mission in Large
    Fork- 2013 Fox Float 34 160mm travel with CTD and 15mm thru axle (air)
    Shock- 2013 Fox Float with CTD, boost valve (air)
    Brakes- 2013 Avid Elixer 7 Trail hydraulic disc brakes, 200mm rotor front 180mm rotor rear
    Bars- DB Probar 740mm wide 25mm rise
    Stem- Easton 31.8mm
    Frame- Mission All Mountain 6061-T6 Weapons Grade Aluminum (19''/large frame)
    Front Derailleur- Shimano Deore
    Rear Derailleur- Sram x9
    Rims- 32h AM260HD Doublewall Disc
    Cranks- Raceface Respond cranks
    So with that, a couple questions. Will the large fit or will I be pushing it? Also, what other bikes should I consider that are about the same setup?
    Also found a 2013 trek remedy 7. Looks all stock. 21.5". Seems like the remedy will be a better climber, but the mission has better parts all around that I likely wouldn't have to upgrade.
    Fat-tired Roadie
    Nov 2007
    Large could be too small for you. Depends how much you plan to pedal it.
    I do lift/resort rides only 1-2 times a year. Looking to get more into it though, but also will be riding the local trails. Pedal my ass to the top and have some fun on the way down.
    Fat-tired Roadie
    Nov 2007
    Get a bike that fits. It's certainly worth test riding the Mission. Sizing for bikes isn't consistent and noone can size you over the 'net.
  1. Serfas TSL 1500 (true 1500) vs Cateye Volt 1200 vs other generic lights
    By gmarchie12 in forum Lights and Night Riding
    Last Post: 12-25-2013, 07:44 PM
  2. Replies: 10
    Last Post: 09-03-2012, 03:50 PM
  3. Replies: 19
    Last Post: 01-18-2012, 02:56 PM
  4. Can I fix 'em, or time to upgrade?
    By TravDK in forum Brake Time
    Last Post: 08-21-2011, 08:56 AM
  5. Time for an upgrade
    By Anderoo in forum Beginner's Corner
    Last Post: 04-30-2011, 01:02 AM
