Results 1 to 6 of 6
    Tell me about Bottom Brackets
    I'm a newbie wondering about bottom brackets; how/if they need maintenance, or do you just replace them when they go bad? How much life is typical? How do you know when they are going? How about adjustments? Just a quick overview for the new guy would be awesome for anyone that cares to share. Or even just a link or reference to where I can get some info. Haven't found much.
    Thanks in advance!!
    Most newer bikes have sealed bearing ,no adjustments . You can tell when they are bad by the way it feels when pedaling /or the noise they make. How long they last depends how /where/when you ride.Have you looked at the Park tool web site or Sheldon Brown site ?
    Park tool does have some good info. Thanks for the tip. Anything else guys?
    Reputation: Nubster's Avatar
    When it's time to replace, get something a little nicer that can be serviced. Personally I like external cups but that will likely require a new crankset as well, but that's not necessarily a bad thing.
    Kona Big Unit SS
    Kona Private Jake SSCX
    DiamondBack Release 3
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Bottom brackets should occasionally checked to make sure they're in there tight. Usually once a season I'll pull mine out and make sure it has grease on it. And if your bike is making noise, there is almost always something that needs attention. One exception is sometimes brake and shifter housing rub and make noise; not much you can do except try to pad where they rub.
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    I've tried a few sorts over the years. Pressed in bearings and square taper on my Klein. Square taper cartridge units circa mid '90's. ISIS drive with sealed bearings. External bearings.
    The constant thing is that they will ALL start to creak after a while, esp. if you are riding in wet conditions or use a high pressure washer.
    A common source of creaks is that the BB has been installed with no grease on the threads of the cups. Or crank spindle bolts that aren't tight enough.
    When they really crap out they creak like mad and you can detect loose and worn bearings because the cranks can be "rattled" slightly.
    Regular servicing and cleaning and lubing can make them last longer, and making sure your bottom bracket shell isn't full of water.
    I serviced a mate's ISIS drive BB the other day and a half a cup of water gushed out of the shell when I pulled the BB out.
    Less isn't MOAR
