Results 1 to 32 of 32
    May 2010
    Tektro Auriga Pro Vibration
    I picked up a Rockhopper SL Base from my LBS a short while ago and have had a chance to put some mileage on. While the bike as a whole is fantastic the brakes are causing me a bit of trouble.
    It came with Tektro Auriga Pros and these rotors:
    The power is definitely there but I get a relatively pronounced vibration from the rear any time I use it. Performance doesn't seem to be affected but it is really getting annoying considering the vibrations translates into any body part that is is contact with the bike at the time.
    I've taken it to the LBS I picked it up from and they did some adjustments but the problem still persists.
    I'm a newb at discs/hydros so I'm hoping someone could at least point me in the right direction for solving this.
    First I've heard of a Spec. vibrating. I know Gary Fishers are known for it, like the HiFi. You can try organic pads and see if it helps but it might be something you can't solve.
    Quote Originally Posted by rkj__
    "It's amazing how people can make bicycle riding seem so complicated on the internet."
    May 2010
    Quote Originally Posted by Mount Dora Cycles
    That certainly would be tragic considering how nice the bike really is. Anyone else with an SL frame experience this? If I'm not mistaken the entire Rockhopper SL lineup should share the same frame.
    meow meow
    Reputation: b-kul's Avatar
    i think its a combo of the breaks and the rear end. you can try new pads and if it still persists and is really bugging you you can try a new brand of break.
    Jun 2010
    It's not the brake. Had a friend with a similar issue, turned out to be a crack at the dropouts.
    2008 Rockhopper Disc
    Fulcrum Red Metal 3 wheelset
    Rock Shox Reba Race
    XT brakes
    May 2010
    I spent some time outside with the bike and some tools tonight and I can't for the life of me get the vibration to go away. I tried reversing the pads (so the pad was on the opposite side of the rotor) and swapping front to rear. There was absolutely no difference throughout any of it.
    I also tried re-centering the calipers but still the problem persists.
    When the LBS tried to resolve the vibrating they said they gave it their best shot. Should I give them another crack it at? Would it be appropriate to ask them about alternative solutions like replacing the brake system? If so should I ask for a discounted rate?
    ask for a new bike.
    May 2010
    ask for a new bike.
    Even though I've owned it more than a month and put ~200 miles on it?
    Yep, ask for a new bike since they can't resolve the problem.
    Quote Originally Posted by ridelikeafatkid
    "MOMMY, I WANT TO RIDE LIKE THAT FAT KID!" true story.
    Reputation: rdickens48's Avatar
    You could try and see if tightening up the quick release helps. I get some vibration on my front end if my quick release isn't tightened enough.
    May 2010
    Quote Originally Posted by rdickens48
    Tried that one too. Caliper, quick release, adapter, etc is all tightened down.
    EDIT: To give you a better idea of what I'm talking about it's bad enough that I can feel the vibration in handlebars and saddle. Sound wise I'm not sure what I could compare it to but it will drown out someone's voice riding next to me.
    As long as you bought it from a LBS, they will take it back.
    Reputation: faceplant72's Avatar
    I have had similar problems with the rear Tektros on my Mongoose. It seems to come on with dirty rotors after riding the flats alot. The best I have found to mitigate the issue is to clean the rotors with IPA and the get them really hot. I ride up the step slope in front of my house and then ride back down applying the the brakes. After the rotors are way to hot to touch the vibration goes away for a few more rides. Getting the brakes really hot seems to clear up the vibration more than just cleaning.
    Jun 2010
    I still say it's the frame. As others said, it might be "normal" on some other kind of bikes but not yours. The frame either has an invisible crack, or it's just plain faulty. It's fully covered by warranty.
    Rock Shox Reba Race
    XT brakes
    May 2010
    Thanks for all the info and advice!
    I did try getting some speed down a long slope and then applying the rear brake with authority but that didn't seem to do much either.
    For those thinking that there is a crack in the frame: would I be able to see this crack? Where would it likely be?
    I hate rock gardens
    Reputation: TwinBlade's Avatar
    Jun 2010
    Quote Originally Posted by MNiceGuy
    Absolutely.
    Hell, 99% of LBS let you try a seat out for 30 days with the option of returning/swapping it...
    MTB NAME The Hammer
    May 2010
    Quote Originally Posted by TwinBlade
    Absolutely.
    I plan to call them up this morning. This particular LBS has been very good to me so far so I have high hopes.
    Just to clarify some information:
    The vibration I mention isn't a shuddering like one would expect from a damaged/warped rotor. This actually sounds like something is making the frame resonate. Also, the RPM of the wheel doesn't seem to affect the pitch but it does affect volume.
    May 2010
    I dropped the Rockhopper off at the LBS I bought it from and who serviced it for the brake issue previously. I have my own thoughts and feelings but I'd like to bounce some of the information of someone else.
    The tech took the bike for a spin and agreed the rear brake was rubbing/squealing obnoxiously and it was one of the most pronounced examples he'd seen. He proposed changing the rotors to another design. I'm not one to go against the recommendation of someone much more experienced than myself so I accepted the diagnosis. The only problem is that the LBS wanted to perform this upgrade (to Avid rotors) at my cost. When I disagreed with this they said they would give me $20 per Tektro rotor coming off and then I would just have to pay the difference. The train of thought from their perspective is that the brake is fully functional it just has a very obnoxious side-effect. Since the part isn't functionally defective it's not a matter of warranty replacement or anything along those lines.
    I then asked how we would proceed if the new rotors didn't solve the issue to which I was told they would try new pads (again at my cost). If that didn't work we would have to start replacing the braking system itself.
    Facts to consider:
    1. The bike was purchased 6/04
    2. Has already been in service for the same issue at the same LBS
    3. I bike fairly regularly and I'm a little disappointed to have it stuck at the shop again.
    4. It's a 50-60 min drive to the LBS
    5. I don't want to pay out to have brakes that don't squeal like crazy and vibrate every body part in contact with the bike.
    6. This LBS has been very good to me throughout my 'return to cycling'
    7. My girlfriend and I have dropped about $2300 total at this LBS for the bikes, gear, and roof rack.
    What are the thoughts here?
    I hate rock gardens
    Jun 2010
    Show them the receipts and ask them if the nominal cost of brakes is worth them losing another $2300 in business.
    That is total BS IMO. They are nice because you just made a couple months rent for their building. Of course, I am saying this for what I would do.
    2 hours in gas in my truck would be about $20.
    Then again, I don't at all mind getting sh!tty with someone when they are jerking me around. You are getting jerked...pretty bad too.
    MTB NAME The Hammer
    Are the brakes new to the bike?
    If not then here is something to consider; 6 year old bike and the problem just started and the mech thinks it's a rotor design problem? WTF was he smoking? Did you ask about checking the frame, frame warranty etc?
    Quote Originally Posted by trboxman
    It's a month old bike, not 6 years old.
    MNiceguy, this is not something you should have to live with as a "very obnoxious side-effect". If they can't fix it, they should give you a new bike. It's absurd that they want to charge you for new rotors. If they refuse to fix or replace the bike, you need to call Specialized. If that doesn't do anything, let me know.
    May 2010
    Thanks guys!
    For clarity the bike was purchased 6/04/2010 and is completely 100% original.
    I had my boss take a whirl on a the Rockhopper. I told him there was an issue with the brakes and left it at that. He rode to the end of the parking lot and as soon as he pulled the lever to slow for the u-turn (approx 30 yards away) all my co-worker and I heard was ZZZZZZzzzzzzzzzzztt. He also commented on the main problem: imagine a high-pitched resonance being transmitted to your tailbone and 'goods'. Bad touch.
    Not only can I not afford to upgrade up, up, and beyond I really don't want to end up in a perpetual cycle of bringing it in to troubleshoot the problem. I've been down that road with a car before and it's just some bad energy to bring into one's life to say the least.
    I left it at the shop to give them a chance to look at it and give myself a chance to talk about it and get some feedback. I'm concerned that they will IPA the rotors, sand the pads, and send me back out the door. I know it's not a tightness/centering problem because I messed with that for about 2 hours last night. I hate to take the bike back only to have to make a return trip.
    I can get a '09 FSRxc for about the same money and ironically it's equipped similarly if not better than the '10 SL (the FSR is a closeout model). Would it be reasonable to request a transfer to the new bike?
    Doubt that will happen but you can ask. What they need to do is ship it back to Spec. and have them send you a new bike.
    May 2010
    If that is the path I end up taking how long could I expect to be without a bike?
    Jun 2010
    If they think it's the rotors (not saying it's impossible), at the very minimum they should have just installed some kind of used or whatever rotor for you to try.
    I just happen to own a Rockhopper too and know that this frame actually _smoothes_ any kind of vibrations from the wheel. My friend with the cracked frame also had a Rockhopper. Btw, the crack wasn't visible at all, he took in the bike with very same issues as you and they told him (after looking into the brakes) it was a frame issue. They didn't give him a new bike just installed everything on a new frame, which they had to order so it took some time, oh and the bike was more than a year old.
    Rock Shox Reba Race
    XT brakes
    Reputation: kiwi_matt's Avatar
    Have you tried using a different adapter? Might be an idea to see if the brake mounts need facing too.
    It's the shop's responsibility to fix it. Just because the brake works, doesn't mean they aren't responsible for it. The repair should not cost you money. If they keep giving you problems, then call Specialized at (877) 808-8154 and complain to them. Specialized does not look kindly upon it's dealers behaving like that.
    May 2010
    Problem Solved!
    I had a conversation with the LBS manager and brought my concerns to him. He asked me how I would like to proceed so I answered as honestly as I could and requested a new bike. That way I could just have something that worked without hassling with repeat issues. To my surprise he said it wouldn't be a problem and asked which bike I would like to replace it with. The only choices that didn't involve stepping down was a '10 Rockhopper SL Comp 29er for $200 more or an '09 FSRxc for approximately the same price. I chose the FSR.
    Thanks to everyone who chimed in this thread! Case closed
    local jackass
    Reputation: biggoofy1's Avatar
    congrats on getting it all worked out and welcome to the Xc family now post pics and get it dirty
    His
    2010 FSR XC
    2010 ALLEZ
    Hers
    2012 Myka 29'r
    2009 Cannondale Synapse 5
    Down East Cyclists
    I hate rock gardens
    Jun 2010
    Problem Solved!...Case closed
    Excellent! Glad it worked out for you. That is the way it should have worked in the first place, but the important thing, is you can now carry on without worry and frustration.
    MTB NAME The Hammer
    Glad they resolved it. Hope you enjoy your new bike. It's a bit heavier and has more moving parts to fail in the future, but hopefully no more vibrations. Glad the LBS stepped up!
    Problem Solved!
    I chose the FSR.
    Score!
