Results 1 to 31 of 31
    Apr 2014
    New question here. technical climbing - sit or stand?
    Coming from background of roadie racing in the early 90s I never stand on the technical climbs. Am I giving something away doing that? The only time I get out of the seat is for any log crossing or a particularly sharp edged rock or root, but that's mainly for comfort. I seem to make it up the toughest climbs I've found on my own that are rideable, but I'd like to know if it's something to get good at as I pretty much consider myself a climber...
    Trek Superfly 100 AL elite with Shimano SPD clipless pedals.
    I like bikes
    I'd rather be on my bike
    Reputation: TenSpeed's Avatar
    Feb 2012
    If you are able to do it seated, and you are making all of the tough climbs, I would say that you are already doing it correctly. Why change?
    The pedals turn, not just the left one, but the right one too.
    Reputation: Thyamine's Avatar
    Jul 2013
    On climbs I always sit. It puts more weight on the back tire giving better traction and less slippage. Sometimes when sprinting up a paved surface or some trail surfaces I may stand for a short stint, but 90% of the time I find sitting to be more effective due to the friction/traction advantage.
    2012 Specialized Carve Comp 29
    IMBA Member
    Team J3 :: http://www.ridej3.com
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Seated, in a slightly higher gear is ideal.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Reputation: J.B. Weld's Avatar
    For me there are a ton of variables and I mix it up quite a bit depending on what they are. If I have some decent speed and come to a steep, but not too long pitch it's usually better for me to get out of the saddle and power up in a taller gear rather than shifting down and sitting. Similar situations often come up during long climbs where I find that standing to get over steeper sections instead of shifting is faster and also conserves energy (as long as traction is available).
    Apr 2014
    Just making sure as I'm in the ride 3-4x a week stage and watch videos on YouTube and I saw more standing up than I was expecting.
    I like bikes
    beater
    Reputation: evasive's Avatar
    Feb 2005
    What do you consider technical? I would say that a technical climb is something that requires me to shift my weight around to maintain traction or burst up/over something. In these situations, I am almost always out of the saddle, or at least just lightly perched on the saddle nose, but not putting much if any weight on it. For example, desert SW style rock ledges, or rock gardens.
    because GIANT
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    the answer is, it depends
    some climbs I pick through, next day same climb I hammer in big ring and everything in between. stand, sit, stand then sit, sit then stand. whatever
    depends on the climb, traction, rocks/roots, grade ...everything. there is no correct answer than just ride it
    typically for the climbs so steep the front wheel has a real hard time staying put (essentially a no-fall zone) those are always 'seated but barely seated' with fine tuning weight distribution by the microsecond
    Yeah.. It really depends. In perfect, smooth, gradient inclines, I'd sit.. But where I ride, with roots and rocks and trees, I may sit or stand depending on the incline, turns, obstacles, etc.
    Sent from my 831C using Tapatalk
    Apr 2014
    Quote Originally Posted by 127.0.0.1 View Post
    Yeah this is east coast woods. A fair amount of roots, not much for rocks usually and steep enough to not see many (usually none) wheel tracks going all the way up. One in particular is a mixed use trail with a horse farm nearby, the trail is never mtb manicured smooth through there between the water erosion and horseshoes tearing up the softer top soil. I'm guessing steeper is possible, the normal seated position would have you flip off the back of the bike, I just haven't found it yet.
    I like bikes
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    If I can do it fully seated then the climb is not very 'technical'. It's just a climb. On techie stuff I always need to get my butt off the saddle at least a bit so I can move around, or lift the front.....or lift the back.
    Here is one of my favorite vids of a local trail here in town. It shows some good examples of technical up hill riding. 1:50 is good example of having get off the saddle but if you watch closely Kenny gets off the saddle slightly quite often. Not a full on stand up, like if you were stretching your legs but rather just giving room between your butt/thighs and the bike.
    Bike rider and videographer credits go to local rider and Pivot rep Ken Bennett.
    <iframe src="//player.vimeo.com/video/10941473" width="500" height="281" webkitallowfullscreen mozallowfullscreen allowfullscreen></iframe>
    Reputation: time229er's Avatar
    Oct 2013
    Quote Originally Posted by Zachariah View Post
    or a slightly lower gear could be ideal...
    2014 Nail Trail 29...
    Reputation: JoePAz's Avatar
    May 2012
    Quote Originally Posted by eatdrinkride View Post
    That is exactly how I describe it. Technical climbs are ones where the climbs are limited by your ability to get over rock, roots etc. Non technical climbs are lungs/legs. This applies to short 100 yard climbs or longer ones. When just climbing I tend to be seat and for very steep, smooth climbs seated works well when sitting on the tip of the saddle. I keep the front end down and it gives good rear traction. However when rocks and roots come into play I will climb in "short stand" position where my butt is only slightly off the saddle. Just enough to put all my weight on the pedals and order handlebars. This allows me to quickly move my weight to get the right front end grip and rear grip as well as being able maneuver the bike and let the rear wheel come up over ledges. Done just right it amazing what you can climb up, but it is all about perfect balance and control. It does take alot of strength and energy to climb like this so I use this technique only when it is critical to clear certain sections of a climb.
    Joe
    '18 Specialized Epic 29", Vassago Verhauen SS 29", '13 Santa Cruz Solo 27.5", XC, AM, blah blah blah.. I just ride.
    Fat-tired Roadie
    Nov 2007
    Whatever works.
    For a while, I was doing most of the really low-speed technical climbing sections with my butt on the saddle. It helped me maintain traction. There are a couple problems with that approach, though - sometimes I'd loop out on really steep bits, and it was hard to move further forward over the bike once I was committed. And, it was hard for me to help the bike up and over a ledge.
    Lately, I'm climbing out of the saddle more. It's actually more about higher-speed situations. I washed out my front wheel the other day and realized I'd gotten into a bad habit of pulling back on the bars when applying power in climbs. This messes with my weight distribution, and I realized it had also been making it harder for me to hold a line, say over a root bed or something. When it gets really steep, I can maintain better weight distribution by getting out of the saddle, just a little bit, and moving forward over the bike. The above poster mentions a "short stand" - I think I've stumbled into about the same idea. It's very different from the tall, hips-forward stand I'll sometimes do when I want to stretch my legs and maybe need to put some power down but traction and handling aren't really a problem.
    Reputation: borabora's Avatar
    Maybe this question just high-lights my biking shortcomings but when things get really steep how do you avoid having to stand? At a certain steepness I simply cant't keep the front wheel down - even if shifting my butt to the front of the saddle and bending my torso forward. In those cases I need to stand to move more weight forward unless I want to wheelie up the hill. Is that just me? I don't mean to hijack the thread -- it seems relevant.
    Quote Originally Posted by borabora View Post
    Those are the times when I find I miss bar-ends.
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
    You can have bar ends!
    beater
    Feb 2005
    I've only encountered a grade so steep that standing was the only option at one place: the Slickrock Trail. Those grades are essentially unclimbable on dirt, where the traction isn't as remotely as good as on rock.
    In my experience, I'm not smooth enough at pedaling out of the saddle to avoid spinning out on dirt at any grade approaching Slickrock steep. But, I can climb pretty steep grades by scooting waaaaay forward on the saddle and being smooth.
    Quote Originally Posted by ou2mame View Post
    Style maven says no!
    I actually don't do even remotely as much climbing as I used to, but I would totally rock bar ends if I did. I spent a lot of time on them bitd and really appreciated the range of body position and grip options they afforded.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    They make those ergo ones now that are aerodynamic lol
    I think we all miss them just a little bit.
    since 4/10/2009
    Reputation: Harold's Avatar
    Huh? Aero on a mtb?
    If technical, I'm usually out of the saddle. If not, usually seated depending on how hard I'm pushing it on the climb. If I'm really hammering, I'll be standing.
    Reputation: bigkat273's Avatar
    Re: technical climbing - sit or stand?
    Quote Originally Posted by evasive View Post
    ^this. Riding in Pennsylvania as I do requires one to be very dynamic when climbing. A large majority of my climbs have multiple pitches often separated by waterbars/big d@mn roots so you have to roll with the punches so to speak. Long story short do whatever works for you and your terrain.
    Jul 2013
    I use platform pedals, so my best option is to stand for more efficient/power pedaling on climbs.
    In the future, I will try clipping in to experience power pedaling even while seated.
    What works for me may not work for you. What's best for you depends on many factors. We are different from each other.
    Well it depends, how is your cockpit set up? If your saddle is too far back, and/or stem too short, maybe that's limiting your ability to keep the front wheel down. If you're using a setback seatpost, it's worth trying a straight one to play with saddle position a bit.
    Fat-tired Roadie
    Nov 2007
    I was still using bar ends about a year ago.
    I think wide bars make it a little easier to get forward without them. With narrower bars, I'd start to feel pretty cramped.
    Or, maybe I just got accustomed.
    I do miss them now and then when I do an extended period of steady-state riding. I'm lucky enough not to do that often when I go out to do MTB, however.
    On the steepest pitches I have to stay seated, well sort of- if you call having the nose of the saddle jammed up your @ss seated, otherwise I got no traction. I do need some new tires though.
    Quote Originally Posted by NateHawk View Post
    Huh? Aero on a mtb?
    Makes a big difference when I'm climbing like I usually do - like a slug up a salt pile.
    I still have a set of Ibis Rosie ends kicking around, those things were awesome. I might have to throw together an old-school rig just so I can rock those and my mint set of Spin wheels.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    since 4/10/2009
    That word. I don't think it means what you think it means
    Sent from my DROID BIONIC using Tapatalk
    Reputation: solarplex's Avatar
    Apr 2014
    I try seated and lay my chest close to the bars as possible. Some times im wrong geared or i pop off a rock or root and i need to stand up and torque up the hill. I prefer sitting but stuff happens.
    Fatbike, XC bike, Gravel Bike....
    Professional Crastinator
    Reputation: Fleas's Avatar
    My butt is the damper and bump stop for my rigid bike.
    If I can stay seated, the climbing is not very technical, but I will let the seat hit me so I can keep the rear tire planted. If you ride a 5" bike, then maybe you can stay seated - at least until you loop out.
    Find some shallow stairs to ride up. See if you can do it seated.
    -F
    It's never easier - you just go faster.
    How about 'facetious'?
    Sinister Bikes
    Wraith Bicycles
    NEMBA
  1. Repair Stand Mounted Wheel Truing Stand?
    By homey in forum Tooltime
    Last Post: 10-08-2016, 11:25 PM
  2. Replies: 19
    Last Post: 05-01-2014, 07:59 PM
  3. Need technical help with new-to-me EG
    By Blatant in forum Titus
    Last Post: 04-24-2013, 09:05 PM
  4. good technical climbing AM (~6") bike
    By tosa in forum All Mountain
    Last Post: 07-17-2011, 08:13 AM
  5. Sustained Climbing or Climbing Repeats? What to do.
    By vetprowanab in forum XC Racing and Training
    Last Post: 06-18-2011, 11:06 AM
