Results 1 to 6 of 6
    Swapping a HT Frame for a FS Frame
    I have a 2010 Giant XTC HT. I was considering getting an Anthem frame (pr any other for that matter) and installing the XTC components and fork on the new frame.
    I have never built a bike, would this work?
    Fat-tired Roadie
    Nov 2007
    Maybe. You need to go through the way each of your existing components mates to the frame.
    Places you may run into problems in particular are the axles, the front derailleur clamp size and swing, the bottom bracket standard, the headset standard, the amount of fork travel, and the seat post size.
    If you stick with XC frames (can't remember if the Anthem is the XC or Trail model) I'd expect you to be able to transfer most of your parts. But you should expect to have to buy some new stuff too.
    Reputation: Bigb2000's Avatar
    May 2013
    It's the little stuff on a ht to fs swap that add up. Like, brakes lines are too short, shifter cables too short, bottom brackets might be different, hub widths and axle sizes are off. It's tempting to just buy a frame and swap over, but unless I had really top line parts; I'd look at the price difference in selling the old bike and buying prebuilt. The selling of old + buying just frame might be close to buying a complete fs bike with new everything and warranties.
    The Anthem is an XC frame but i dont know how similar the geometry is.
    Thanks guys this is the info I was after. I realize that the cables would need to be replaced. I guess my main concern is the fork and headset. I never thought of the axel width or clamps for the mechs. I will do some research and not rush into it. Spending ~$1,000 or less for the frame is attractive but I see that there some extra costs to consider.
    Fat-tired Roadie
    Nov 2007
    It's only the front derailleur clamp. And if you move your fork over (very likely possible, though a different headset is likely too) you'd only need to worry about rear wheel compatibility. So this is not insurmountable, but it's good that you're going to take a little time and figure out in advance what you'll need.
    Reputation: faceplant72's Avatar
    Since we are talking Giant here watch the forks and headsets. Giant has gone to the proprietary Overdrive 1.25-1.5" taper fork. There are headsets out there that allow other fork combination but there is a lot of fine print reading.
  1. Swapping a medium mtb frame for a small compatibility?
    By johnjaundice in forum General Discussion
    Last Post: 12-22-2013, 07:42 PM
  2. Frame Swapping - What Am I Looking At?
    By davidlax12 in forum Beginner's Corner
    Last Post: 01-11-2013, 12:10 AM
  3. Should I bother swapping out this frame for another?
    By roc865 in forum Bike and Frame discussion
    Last Post: 07-16-2012, 03:56 PM
  4. Swapping cyclocross components to 29er frame
    By shackleton47 in forum 29er Bikes
    Last Post: 12-27-2011, 10:07 AM
  5. Swapping FR frame for AM heavy duty, need inputs
    By David C in forum All Mountain
    Last Post: 10-05-2011, 10:08 PM
