Results 1 to 6 of 6
    Suspension type for AM bike ADVICE PLEASE
    I have been getting mix advice on to which bike I should get. I did a lot of reading and I think all mountain is going to be the type of riding i would be doing. Some of my friends told i should go for a full suspension, other told me to go for a front suspension only because it is easier to hop. I'm a newbie and this is really getting confusing... so any help would be great.. thanks
    What's an "AM" bike? How much are you looking to spend? Why do you think you need an all mtn. bike?
    Your bike is incorrigible
    Reputation: Guyechka's Avatar
    There are only two factors you need to consider here. First, how much money are you willing to spend? I decent full suspension bike is going to start around $1200 (I'm thinking Jamis), while a hardtail is going to be significantly cheaper. Secondly, how comfortable do you want to be on the bike? Full suspension makes life a hell of a lot easier by providing more control and taking some pressure off your back. If you plan on riding longer trails with roots and rocks, then go with the full suspension. On the other hand, if you are just going to be tooling around on easier trails, then a hardtail will be just fine.
    The fact that you can bunnyhop two extra inches on a hardtail should not make any difference. And, yes, that is about the amount of difference in hopping power between the two. Most of that comes from the tiny bit of added weight a full suspension will have. In other words, full suspension is just as easy to bunnyhop as a hardtail.
    Thanks, for the advice! I saw some used full suspension bikes for around 400-850. I found a Jamis Dakar, a Haro X3, and a new Haro X6 for 899. From what I read, the haro is a little on the heavy side. I heard some good things about Ironhorse too.
    Quote Originally Posted by ldanny
    I would go with the Jamis Dakar over the other two. The Haro isn't horrible, but it is heavy. Ironhorse tends to make better high end bikes and skimp on their lower end bikes.
    Bike to the Bone...
    Reputation: rzozaya1969's Avatar
    To quote Dogonfr, another mtbr.com member, check Ibex bikes:
    http://www.ibexbikes.com/Bikes-Hub-MTB.html
    They seem to be a great value, but you must buy from their site. It's just another option to look at.
    Also, the advantage of buying a hardtail (or HT or what you refered as front suspension only) is that your skills will be better starting with a HT and later on buying, if you want, a full suspension (or FS).
