    Suspension seatposts...worth it for me?
    If you are planning rather leisurely rides in the backcountry on two-tracks and game trails, is a suspension seatpost a good investment?
    Thanks,
    Jim
    I ride mostly on rocky loose stone and rutted ground so invested in a thud buster, not the cheapest solution (around 100$) but imo worth every cent. It doesn't turn your bike into a full suspension setup, and is not designed to, but if you are looking for something that removes all the "chatter" and jarring from uneven ground this is the kit to get.
    You can often find good used Rockshox suspension seatposts on ebay for cheap. I put one on my Norco Charger and it helps to absorb the sharp impacts. There are several on ebay now.
    http://search.ebay.com/search/search...ost&category0=
    bi-winning
    Reputation: rkj__'s Avatar
    I wanted a Thudbuster, but due to the price, i always held out. Later, my hardtail frame cracked, and i replaced it with a fs, which was what i really wanted.
    As mentioned, the thudbuster does not turn your bike into a fs, but it does make the ride more comfortable. The LT model has quite a bit of travel, which imo, can feel a little weird as it swoops rearward. The ST model has less travel.
