Results 1 to 3 of 3
    Wizard of the Trail
    Reputation: Geist262's Avatar
    still looking for a frame
    Hey guys,
    I have been looking to get a new frame. Has anybody ever dealt with adrenaline bikes. I saw a good deal on there. Also, I was looking at an iron horse warrior pro in a 17 inch. Does that sound big for me. I am 5'6" with about a 28 inseam. Thanks.
    There is no charge for awesomeness......or attractiveness.
    Good rep does not wash out the bad, nor the bad the good.
    Feb 2005
    FS or Hardtail?
    What type of frame do you want or what type of riding do you plan on doing? I'm 5'7" and I use a 17" Giant XTC frame. It's a hardtail and fast as hell, it actually accelerates going uphill. Why are you buying just a frame?
    If you're not falling, then you're not riding fast enough!
    Ibex Asta Pro SE & Giant XTC-2
    the size sounds right
    I think that size is right for you.
    28 inch inseam seems a little short for your height but these guys have a lowered top tube so it should work out fine.
    Keep in mind that if you put a longer travel fork on it than original spec that the top tube will be raised as well and you may encounter some clearance issues.
    http://www.ironhorsebikes.com/bikes/...arrior_pro.gif
    FT
