Results 1 to 5 of 5
    Super Clyde
    Reputation: askibum02's Avatar
    Steel vs. Aluminum vs. Carbon
    I'm sure this has been covered ad nauseum, but this is kinda of specific to me. I'm a Super Clyde at 6' and 345#. I demoed a Niner Air 9 RDO today and I liked it a lot, but I'm a little hesitant to buy carbon because of my size even though the Niner rep said there's no weight restriction on their carbon frames. He said it I was hesitant to buy carbon I might like steel better than alloy. I haven't ridden steel in over 15 years and I was too young to know there was a difference in feel between alloy and steel. What is the difference in feel between the 3? Which ever frame I get I will be building it up with a lefty fork and X0 components.
    Sent from a telecommunication device with a touch screen keyboard.
    I wouldn't **** you, you're my favorite turd.
    T.W.O.
    Reputation: mimi1885's Avatar
    Not really a whole lot. As for the ride quality it's not so much the material anymore. Designer can make any material ride like another by manipulating shape and size of the tube. If you like the affordable price go with the Alu, classic feel why not steel, bling and light weight then carbon.
    If the rep said there's no weight limit and you can verify that then it's all good. If carbon is so fragile there would be tons of lawsuits, I've not heard of any. That said, right tool for the right job. Air9 RDO is a XC race frame, and while every one like light bike is it the right bike for you? If you are into more descending than climbing then ROS 9 would fit the bill better.
    I like pie.
    Reputation: Mr5150's Avatar
    Dec 2011
    In my experience steel gives a better ride than AL. My HT is high end steel and it is a pleasure to ride. I've tried a bunch of good AL HTs and they were fine, but did not have the smooth ride of my HT.
    As to Carbon, I have no experience. But the idea of a nice riding frame that is two pounds lighter is appealing. OTOH I could get a custom steel frame for less than an off the rack Carbon frame.
    Fat-tired Roadie
    Nov 2007
    I wouldn't worry about the Niner carbon if you can afford it. An acquaintance of mine observed that carbon rims have taken over from aluminum in competitive DH because it's possible to make them stronger. Read the warranty terms, if you're worried.
    Bear in mind that regardless of material, a bike frame will be as strong as it was designed to be.
    TXTony
    Guest
    Intended purpose...warranty..verify through the manufacturer..and pretty much what the others have said..I think my next rig is going to be steal for trail use...rigid...
  1. Steel vs aluminum frames....
    By comphynum in forum Beginner's Corner
    Last Post: 12-04-2012, 05:14 PM
  2. Steel vs Aluminum
    By hozman67 in forum Singlespeed
    Last Post: 06-20-2012, 10:52 AM
  3. Steel vrs Aluminum backing?
    By JeffcoHo in forum Brake Time
    Last Post: 05-26-2012, 02:49 PM
  4. AM Hardtail - Steel or Aluminum
    By jbf in forum All Mountain
    Last Post: 03-02-2011, 04:04 PM
  5. Steel or Aluminum frame?
    By Evo. in forum 29er Bikes
    Last Post: 01-17-2011, 07:46 AM
