Results 1 to 8 of 8
    Standover Height
    I wear 36 X 30 pants, yeah, a little tubby, I measured with a tape measure and appear to be about 29/30 from straddle to ground. what would be the best frame size for me? 16", 17",...?
    Reputation: erginguney's Avatar
    Dec 2005
    Quote Originally Posted by Cedarbranchbiker1 View Post
    I'm not sure what "straddle height" is. Do you mean the height of the lowest point on the bike's top tube from the ground (i.e., standover height, as in your thread title), or do you mean the "saddle height" (meaning the seat)?
    If you're referring to the standover height, that's the least possible measurement question to answer in a vacuum. For a given bike size, the standover height of a bike can vary wildly, while many other dimensions (like effective top tube length or saddle height) don't as much.
    Your best bet would be to go to a bike shop and try out a few examples in person. Is there any special reason that you avoid that?
    Looking for local rides? You'll find plenty on my website: Bay Area Mountain Bike Rides.
    Mar 2011
    I've learned you want as much clearance as possible on a MT bike.
    I'm 5' 6" on a 18 inch medium frame and just today I blew a tire and fell off the pedals onto my nuts.
    Get the smallest frame possible for your nut's sake, but don't get so small that you're all cramped up on it.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    "Standover" is actually a poor way to size a bike, effective top tube length, cockpit length and reach to the bars are more effective ways to size a bike. Competitive Cyclist's fit calculator is very good if fed accurate data. Here is a link to it: http://search.yahoo.com/r/_ylt=A0oG7...LCULATOR_INTRO
    Dec 2005
    Quote Originally Posted by Ganymede_Illusion View Post
    Very true as a general rule.
    Another thing to keep in mind when assessing adequate standover height: The trail surface will not be flat, like the floor of the shop where you'll be gauging the standover height of the bike. So, be really generous, if you value the family jewels.
    Quote Originally Posted by AZ.MTNS View Post
    Also very true.
    The standover height is more like a "make sure it's adequate too" kind of additional condition to verify when making sure that the frame you're looking at is really suitable for you, rather than for deciding which size frame to look at in the first place. I assumed that's why the poster was asking the question, but it's worth pointing out.
    "Straddle" = "crotch to ground". No LBS close by, I live way out in the country, nearest LBS is 30 miles away. Just don't get to that area very often.
    Dec 2005
    Got it.
    Your second best choice would be to look up sizing charts. Most manufacturers make a table available on their website listing which frame size, for any given model, would be suitable for riders of which height range. Start with that, and then verify that the standover height quoted for the particular frame size that's suggested for your height is comfortably shorter (say, by about two inches at least) than your inseam length with biking shoes on (or whichever shoes you'd be riding with).
    Then, when you are at a shop in person for the purchase, you can verify that all of these measurements do hold true by a proper "fitting" (you might want to look that up), and take a test ride to make sure. That is, unless you're planning to purchase by mail order; in which case, double check your measurements and looked-up specs, and pray for good luck...
    Fat-tired Roadie
    Nov 2007
    Total height is actually a better predictor of bike size.
    Also, if you're tallish but have a shortish inseam, you'd do better to size up for more room for your long torso than to size down for more standover clearance. If you're worried about it, some brands have more sloping top tubes than others.
  1. standover height
    By mastiff in forum Beginner's Corner
    Last Post: 01-10-2010, 09:34 AM
  2. Standover height
    By BILLREDD in forum Intense
    Last Post: 09-12-2008, 05:23 AM
  3. Standover Height
    By hakeem in forum Beginner's Corner
    Last Post: 07-02-2007, 01:42 PM
  4. KHS DJ 200,,,does anyone know the standover height?
    By oggfueler in forum Bike and Frame discussion
    Last Post: 06-07-2007, 12:35 PM
  5. Standover height can eat me
    By djmuff in forum Vintage, Retro, Classic
    Last Post: 05-22-2007, 05:03 PM
